Hi guys
I'm still kind of a newbie to Vettes and have a question.
I have a 98 coupe with 65k. I have a small leak oil leak coming from my rear end housing and plan to get it fixed soon. My question is, although it isn't slipping, should I go ahead and have the clutch done at the same time sine the rear end will be torn apart?
Thanks in advance
From your description, the repair you need is a rear axle seal. Unfortunately, this problem is a known issue with C5's. To get to the clutch, there is actually a lot more work unless the plan is to remove the rear suspension cradle.
I recommend taking your car to A&A Corvette in Oxnard. Although they are a performance shop, this is a repair they can definitely do and it will be done right. The mechanic there Jesse, is a technician-genius.
I'm just down the road from you near the LA/Ventura county boarder.
Hell no, don't do the clutch intill you need to. That is alot of work. You can do the axle seals while everything is still under the car. You won't even have to drop the cat back exhaust.
If you guys don't mind me asking. What does something like that typically run?
Just want to be prepared
Thanks for all of the info. You guys are priceless.
Hello i just had to fix that seal also and ot was simpler than i thought, took like 5 hours to do tge two sides. Do some research and try yourself, will save you a ton
