[Z06] Headlight buckets
Old Apr 19, 2013 | 04:28 PM
ErickC5Z06's Avatar
ErickC5Z06
Default Headlight buckets
Well still have headlight issue, I found some plug diagrams for the motors and my motor up wire is constantly hot and motor down barely lights up test light. headlights are down and nothing changes when I turn multifunction switch except lights come on. could the switch be bad or have a bad ground, or the headlight module? any help would be appreciated.
Old Apr 19, 2013 | 04:31 PM
ErickC5Z06's Avatar
ErickC5Z06
ok I put a meter to it and am getting 12 to up and down wires with it unplugged from motor
Old Apr 19, 2013 | 06:02 PM
ErickC5Z06's Avatar
ErickC5Z06
ok im getting power to both up and down circuits from module, o I disconnected plug for motors, and stuck 12 volts to both circuits and the motors didn't do anything. so bad motors AND bad module?
Old Apr 21, 2013 | 02:37 PM
fisher auto's Avatar
fisher auto
Does the car start make sure your battery is good, they have a pretty high draw! Just a suggestion!
Old Apr 21, 2013 | 02:44 PM
ErickC5Z06's Avatar
ErickC5Z06
Yea I think I have it narrowed to control module. I grounded the motor down wire on plug that gpes into control module and bucket came up. Im assuming the module swaps your ground depending on if you're goin up or down
To Headlight buckets
