Help - Can't downshift from 6th to 5th
Old Apr 22, 2013 | 07:33 AM
dcandel's Avatar
dcandel
Oldtimer
Default Help - Can't downshift from 6th to 5th
Just started happening yesterday while out for a long drive. Tried to downshift from 6th to 5th and it won't go in gear. I can downshift from 6th to 4th to 3rd etc, and I can upshift from 1st through all gears to 6th. Just can't get it in gear downshifting from 6th to 5th. I had to downshift from 6th to 4th and back up to 5th.
Any clues???????????
Old Apr 22, 2013 | 07:46 AM
3sACROWD's Avatar
3sACROWD
Are you getting any grinding when you attempt 5th gear? (during up shift or down shift)
If yes, I'd check to make sure your reverse solenoid is functioning properly. If it isn't, the reason you could be having trouble is you're missing the 5th gear gate and hitting reverse.
A shifter alignment would be another thing to perform. No cost and can't hurt.
Old Apr 22, 2013 | 08:53 AM
dcandel's Avatar
dcandel
Oldtimer
No grinding. Just won't go into 5th when downshifting from 6th.
I have an apt. tomorrow and will have the solenoid and shifter alignment checked.
Thanks.
Old Jul 28, 2013 | 01:40 AM
5.3Avalanche's Avatar
5.3Avalanche
Thanks.
Hi,
I'm having the same problem with my C5. I can't downshift from 6th to 5th, but if I skip 5th and go right down to 4th, then I can upshift into 5th.
Did you end up solving the issue on your car?
Old Jul 28, 2013 | 05:23 AM
dcandel's Avatar
dcandel
Oldtimer
Originally Posted by 5.3Avalanche
Hi,
I decided not to have it checked out but try to live with it rather than spend a bunch of money. I started double "clutching" from 6th to 5th and it seemed to work some of the time, but not all the time.
Then about a month ago, whatever the problem was, worked it self out. Now I have no trouble shifting down from 6th to 5th. I don't know why, but it's OK now!!!!!!!!
If you have yours checked out, let me know what you find.
Old Jul 28, 2013 | 09:40 AM
5.3Avalanche
Thanks for your reply. I'm going to try putting in new transmission fluid and then doing a shifter alignment and see if that fixes the issue. I'll report back if that does it.
Did you change your fluid at all before the issue went away?
I also tried double-clutching but it didnt' seem to do anything for mine.
Old Sep 22, 2013 | 10:17 PM
5.3Avalanche
I just spent this weekend changing my transmission fluid and then I performed a shifter alignment. Although shifting from 1st through 6th has gotten smoother, I still can't downshift from 6th to 5th. When the transmission is cold, I can't downshift from 6th to 5th at all, but once it's warmed up, I can blip the throttle while 6th is still engaged and then downshift into 5th and it lets me. It's so bizzare. Has anyone else had this problem? Before I drop the tranny myself to crack it open I'd like to know if there's a less time consuming fix.
Old Sep 23, 2013 | 04:37 AM
Ticket Magnet's Avatar
Ticket Magnet
How many miles on your C5?
Old Sep 23, 2013 | 06:45 AM
5.3Avalanche
85k miles on my car. Everything else seems perfect. It's odd because there are numerous guys on this forum that have had the issue 12-15 years ago when their cars were new, but I've never seen a resolution to it.
Old Sep 23, 2013 | 07:25 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I'm going to check my car. I never realized it has a 5th and 6th gear.
Old Sep 23, 2013 | 07:39 AM
dcandel's Avatar
dcandel
Oldtimer
As I mentioned in my 7/28/13 reply, it just "worked itself out". I didn't do anything to it. Works fine now. I did have the transmission oil and differential fluid changed last week when I had the car in for an oil change (83,000 miles).
To Help - Can't downshift from 6th to 5th
