Stock Exhaust
Old Apr 22, 2013 | 03:08 PM
elopez1986's Avatar
elopez1986
Default Stock Exhaust
Hello Folks,
I am removing my long tubes and replacing them with my stock manifolds with the cat/h-pipe.
My question is if there is anything that goes after the stock manifolds to the H pipe (i.e. reducer, pipe, etc).
Or does it just bolt up together?
A picture or diagram would be useful please!
Thank you!
Old Apr 22, 2013 | 04:41 PM
Looked under mine - if your H-pipe is intact (including the factory cats), then it should bolt right up to the exhaust manifold and the catbacks bolt to the H-pipe at the rear just before the axles.
Old Apr 22, 2013 | 04:56 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Just curious. Why do you want to take off the headers?
Also, it was probably tuned for the headers and possibly to eliminate the rear O2 sensors, so when you go back you may need to retune it to stock.
Good luck.
To Stock Exhaust
