[Z06] Tune help
I have noticed horrible gas mileage lately, like 10 miles per gallon, although it is telling me I am getting better its wrong! Will new plugs and wires fix that??
Also when I go ***** out 1st - 2nd and 3rd the clutch instead of engaging near the top engages about half way? Is that a Hydraulic issue or a clutch issue? I do suck out the old and replace every 2 weeks when I drove it a lot.
I have retired it from a daily driver to a garage queen but with the mileage I am getting its tough to drive it anywhere especially in Phoenix as it is an hour to get anywhere and the way it is running that's a half tank!
Any advice from his forum is welcome!
Redroket
when were the primary o2's last changed?
plugs and wires might still be okay. i changed mine at 90k and they had more life left
fuel filter and o2's are the prime culprit in reduced mpg
Is anyone having trouble with typing on the forum tonite?
you need wix part number 33737 which is $34.46 shipped at amazon
you also will need a 3/8 or 5/16 fuel line tool, forgot which one i used
your o2's are like $25 each at rock auto for OE denso, you just need the two upstream ones which are what control fuel trim
all this stuff with rock auto shipping and the fuel line tools will cost about 100 dollars and take 1hr to install at most
