..Has anyone tried the $ 39.00 kit for the bottom bolsters , I would like to get the bolsters back in a nonmal place without replacing the whole base foam.... Thanks
I bought the kit you are referencing and it worked great. You could probably put together something a lot cheaper but the kit is convenient. It made a difference and my buddies now want me to fix their seats also. It was a good time to fix rocking seat issue too.
Chris
I have also looked at the seat cushion that Bill is probably referencing. It is about $80 per cushion and looks like it has a lot more foam in it. It would still be wise to cover springs with something like the above kit has.
Chris
Chris
thanks for the link.
We sell a ton of these and yes they do work. Even if you replace your seat foam it's wise to add our kit to avoid the same issue.
