I need some odd ball help
Old Apr 24, 2013 | 02:13 AM
wolf10851's Avatar
wolf10851
Default I need some odd ball help
I need to find a way to get a wire from inside the back of my car to the outside of my car near the exhaust. I am looking to hook up a mic near my exhaust to my go pro but like I said I need to get the mic wire from inside to outside the car. we are only talking about a wire that would be like a 16gauge wire and I would like to hook it up near where an exhaust plate would go
Old Apr 24, 2013 | 11:37 AM
02z06dave's Avatar
02z06dave
The easiest thing would be to drill a small hole
Old Apr 24, 2013 | 11:40 AM
chris308's Avatar
chris308
on the driver side behind the carpet is a flap opening (vent) to the outside of the car but still underneath the body panels. I used that to get from the trunk to the area behind the taillights for my satellite antenna.
Old Apr 24, 2013 | 12:34 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I removed my rear license plate back up lights when I added my rear view camera. I drilled a small hole from the inside truck area about center I then ran the wire through the hole and under the hatch carpet.
Old Apr 24, 2013 | 12:51 PM
chipscvettec5's Avatar
chipscvettec5
Yep, drill a 1/16 or 1/8" hole down in the lower middle cowling area. There is a formation in that area which is the top of the exhaust plate. This is exactly what I did to run wire up to my small battery for a LED, works perfect and I doubt any water will get up into it, in the event you should get caught in the rain.
Old Apr 24, 2013 | 02:56 PM
CQRT's Avatar
CQRT
ALL the time - -or just to record a couple of videos?
Old Apr 24, 2013 | 03:44 PM
02z06dave's Avatar
02z06dave
Lol
Old Apr 24, 2013 | 08:43 PM
wolf10851's Avatar
wolf10851
this will be a non permanent thing however it will be used often when I run autox so I will be taking it in and out of the vehicle often
Old Apr 24, 2013 | 08:59 PM
DBLTRGR's Avatar
DBLTRGR
Drill baby, drill!
Old Apr 24, 2013 | 11:04 PM
yaknow's Avatar
yaknow
used the same process to run my CB antenna cable
Old Apr 25, 2013 | 02:50 AM
wolf10851's Avatar
wolf10851
Chris308 THANK YOU!!!!!!!! you are the only one that did not suggest drilling a hole and your solution worked GREAT! I ended up running an audio extension cable through there that way I could plug in the mic when I want to use it and unplug it the rest of the time. the excess of the cable is tucked neatly in the drivers side cubby hole
Old Apr 25, 2013 | 07:23 AM
chris308's Avatar
chris308
To I need some odd ball help
