[Z06] C5 fixed headlight installation
Old Apr 24, 2013 | 04:57 PM
emtmike's Avatar
emtmike
Default C5 fixed headlight installation
I'll be installing my fixed headlights this week. Could somebody give some tips, or pictures to help me out.....thanks
Old Apr 24, 2013 | 11:23 PM
FourG63 97GST's Avatar
FourG63 97GST
which ones?
Old Apr 24, 2013 | 11:38 PM
emtmike's Avatar
emtmike
Originally Posted by FourG63 97GST
which ones?
I ones I bought have 6 LED lights on top, and 6 on the bottom. They came with 4 adjustable brackets for each light. Someone in here had pictures of the ones I bought. I was hoping he had some tips on the installation.
Old Apr 27, 2013 | 11:06 AM
jmac2354's Avatar
jmac2354
Remove front bumper cover, not that difficult, more time consuming than anything. Once the bumper cover is off, removal and installation is much easier.
Old Apr 28, 2013 | 07:57 PM
emtmike's Avatar
emtmike
Got the old headlights out....not much of a problem . Does anybody know if I need to buy a double male harness since the one I have is too short? . I'm going to contact the seller and see how to install the brackets that came with the lights. If anybody has pictures on how to install the brackets, it would be greatly appreciated . Here is a picture of the ones I bought.
Old Apr 29, 2013 | 09:33 PM
emtmike's Avatar
emtmike
Good news...got one of the new headlights in today . You don't have to remove the from bumper to do this, but when somebody tells you that an item is just Plug & Play.....don't believe it . If anybody wants to know how to install these, let me know and I'll walk them through it
https://sphotos-a.xx.fbcdn.net/hphot...32609778_n.jpg
Old Apr 29, 2013 | 09:40 PM
FourG63 97GST
interesting, I've never heard feedback from these yet, curious how they work out in the real world
Old Apr 29, 2013 | 10:38 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Is that a spider on your hood?
Old Apr 30, 2013 | 08:45 AM
emtmike's Avatar
emtmike
Yes, a black widow
Old Apr 30, 2013 | 10:15 AM
BmoreRnsDeep's Avatar
BmoreRnsDeep
How bright are these? Do you have a picture of them on at night? A link to where to get them?
Old May 1, 2013 | 03:38 PM
Zeeeohsix's Avatar
Zeeeohsix
6th Gear
I found them here, although they could probably be purchased on other sites. I'd like to know how bright these are at night. Please post pics.
http://www.slickcar.com/accessories/...conversion.asp
Old May 1, 2013 | 10:03 PM
emtmike's Avatar
emtmike
I'll be installing the passenger side headlight tomorrow night. I will also put pictures on here to let people see how bright they are. I also weighed the old to the new, and I shaved off 14lbs. by putting the LED's on . And if somebody is interested in these, I bought mine off E-Bay from Xcess Motors.
Old May 3, 2013 | 07:05 AM
emtmike's Avatar
emtmike
Well, I got the lights in and went out last night to test them. The low beams aren't too bad, but its much nicer running the highs. Since I'm so low to the ground, nobody flashed me...so we're golden. Sometime layer I'll switch the wires so my highs are my lows. I'll try to get pictures on this weekend.
Old May 5, 2013 | 12:46 AM
The Highlander's Avatar
The Highlander
subscribing.
Old May 5, 2013 | 01:27 PM
RC000E's Avatar
RC000E
Wow...those headlights are.....
Old May 6, 2013 | 01:22 AM
GKennedy's Avatar
GKennedy
Is it 14 pounds for one side ??
Old May 6, 2013 | 02:57 AM
Wood81's Avatar
Wood81
Im getting ready to do these. How long did the install take and did you have to modify very much
To C5 fixed headlight installation
Old May 17, 2013 | 10:45 PM
emtmike's Avatar
emtmike
It took about 3 hours to install both. You'll have to extend the wire harness, and drill a hole for the front bracket. I also had to custom cut the bracket holes to keep it flush with the body. After all this they look great, and are well worth the time, and trouble.
https://fbcdn-sphotos-g-a.akamaihd.n...17873298_o.jpg
Old May 17, 2013 | 10:51 PM
Wood81's Avatar
Wood81
Thanks for the reply. They look great
Old May 19, 2013 | 11:51 PM
JETZ's Avatar
JETZ
Not a fan. Should have gone with 'theradioflyer' projector lights, much better if you want to see at night.
