Alignment needed?
Old Apr 27, 2013 | 09:14 AM
myell01's Avatar
myell01
Default Alignment needed?
Thought I would check here on the forum to get some input. I may have the opportunity to pick up some BBS wheels for my 01 coupe. Even though the stock size tires will be used, the wheels are both 1/2 inch wider than oem. Is an alignment needed after mounting up the new wheels? Thanks in advance for your advice.
Old Apr 27, 2013 | 09:23 AM
damilleniumboy's Avatar
damilleniumboy
You can, but I wouldn't.
Old Apr 27, 2013 | 10:17 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
But if you do I would get an alignment.
I just got one because I had to change my rear outer tie rods.
I couldn't believe the difference in tracking on the highway. I wasn't even looking for a noticeable difference but it was obvious.
Old Apr 27, 2013 | 01:13 PM
myell01's Avatar
myell01
So are you telling me you wouldn't recommend the wheels, or the alignment?
Old Apr 27, 2013 | 06:09 PM
f6john's Avatar
f6john
If you are experiencing good tire wear patterns it's probably not necessary. When I bought my car two years ago, the front run flats were worn badly on the inside edges. I ran them for a few more thousand miles until I located some Z06 wheels and new tires then had the alignment done. Needless to say, the tech said everything was way out of spec. 10,000 miles later tires still look great.
Old Apr 27, 2013 | 07:56 PM
jdot's Avatar
jdot
When I bought my 04 (in 2010) the previous owner had never had alignment checked. I did it just as a formality since the tires were practically new. If you're changing anything to do with how she rolls, I'd have it checked.
Old Apr 27, 2013 | 09:11 PM
You don't say how many miles are on your car now and whether or not your current tires are wearing nice and even. If you've never had an alignment done on the car, it probably wouldn't hurt to have the alignment checked.
Old Apr 28, 2013 | 07:41 AM
myell01's Avatar
myell01
I just put new tires on. The old ones wore even. I was mainly concerned with the fact that I may change something due to the wheels having slightly different measurements. In the interest of preserving the new tires, I think I'll follow jdot's advice and if anything is changed--go ahead and get an alignment. Thanks all.
Old Apr 28, 2013 | 12:45 PM
Big Duk's Avatar
Big Duk
It's cheap insurance.
To Alignment needed?
