Code P0108 H C after LS6/header install
Old Apr 29, 2013 | 09:47 PM
johnsos30's Avatar
johnsos30
Default Code P0108 H C after LS6/header install
Installed LS6 intake and headers on my 99 this weekend. I pulled the codes and got the obvious O2 sensor codes, but also got code P0108 H C which is "Manifold Pressure (MAP) Sensor Circuit High Voltage"
Is this something that needs to be tuned out of my car, or did I pinch something somewhere and need to see what I messed up?
Thanks in advance!
Old May 1, 2013 | 11:57 AM
johnsos30's Avatar
johnsos30
80+ views and no answers. Someone has to know (I hope)!!
Old May 2, 2013 | 12:11 PM
johnsos30's Avatar
johnsos30
Anyone?!?!
Old May 2, 2013 | 12:29 PM
t100driver's Avatar
t100driver
Erase the code, clean your MAF sensor and unhook your battery. See if that works
Old May 2, 2013 | 12:44 PM
Vega$Vette's Avatar
Vega$Vette
Are you running cats?
If so are you running rear O2 sensors?
Did you attach the tube and plug at the map sensor at the rear of the intake?
Old May 2, 2013 | 01:34 PM
johnsos30's Avatar
johnsos30
I will try that. Thank.
Yes, I am running cats. I have the rear O2 sensors in the headers. I am going to have the rear O2 sensors deleted with the tune. I did plug in the sensor, and reconnected the small tube behind the intake
Old May 21, 2013 | 05:20 PM
johnsos30's Avatar
johnsos30
Tried this and still getting the same code. Can this be something that needs to be tuned because of the increased air in and exhaust out?
Old May 30, 2013 | 02:24 PM
danieloneil01's Avatar
danieloneil01
Where's the front O2 sensors installed at if the rears are installed on the headers?
Old May 30, 2013 | 03:03 PM
johnsos30's Avatar
johnsos30
My car got the LS7 clutch installed yesterday at Speed Inc. and they looked at the intake for me. The MAP sensor was damaged. So now it's time to contact JEGS and see what they will do about sending me an LS6 intake with a faulty MAP sensor. Speed Inc. charged me for the new sensor and labor, so now I think it's only right for JEGS to help pay for an unnecessary cost I had pay for. Not mad at the Speed shop since they did great work and helped me out, just a little disapointed at JEGS . Thanks for all the help.
To Code P0108 H C after LS6/header install
