Creak, Groan
Old May 1, 2013 | 09:28 PM
Adoggy Phizzle's Avatar
Adoggy Phizzle
Default Creak, Groan
My 99' is going in tomorrow for a steady creak that goes on when you go over bumps. The car has 26K miles. When I push down on the front end on the side where the shock is, it groans, but the shock seems to work fine. Is there simply lube zirc's or a bushing that may have gone bad for the front end? I'm just wonderwing what I may be looking at. There are no shakes or vibration when driving just the squeaking from the front end when you go over bumps. Ideas?
Thanks in advance,
Aaron
Old May 1, 2013 | 09:38 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Sounds like me when I get up in the morning.
Good luck finding it.
Old May 1, 2013 | 09:49 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
mine did that....lube your sway bar bushings
Old May 1, 2013 | 09:52 PM
o2bnkc's Avatar
o2bnkc
Install the polyurethane ones.
Old May 1, 2013 | 09:58 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Install metal endlinks on your sway bars, adjustable, better feel in corners, no creek, groan, etc. I know did it two years ago.!
Polys are OK but they wear out sooner!
Old May 1, 2013 | 10:05 PM
yaknow's Avatar
yaknow
bushings
Old May 1, 2013 | 10:59 PM
Do that and see if that solves your noise problem.
Old May 1, 2013 | 11:43 PM
Adoggy Phizzle
Thank you all. Once again my life is complicated by bush.....Ings.
Old May 2, 2013 | 12:05 AM
Chicago1's Avatar
Chicago1
your bushings are dry like others said. i suggest you wrap the bar where the bushing sits in teflon tape. its cleaner and no greasy mess and you wont ever have to worry about it again. while your add it upgrade the bars to some c6z51 bars.
To Creak, Groan
