[Z06] catalytic converter
Old May 4, 2013 | 12:30 AM
stockc5Z06's Avatar
stockc5Z06
Default catalytic converter
I have a 2003 ZO6 with a bad cat. A local speed shop has exhaust set up from a base 2003 C5 is it the same or does it have to be ZO6 specific cats? Or could I have some hi-flows welded in?
I do have to pass a sniffer test.
thanks
Old May 4, 2013 | 01:59 AM
racebum's Avatar
racebum
OE cats in general are much higher quality. high flows won't live nearly as long
Old May 4, 2013 | 08:02 AM
stockc5Z06's Avatar
stockc5Z06
can I just swap the intermediate pipe with the cats on to my car? will it bolt right up?
Old May 5, 2013 | 09:06 AM
stockc5Z06's Avatar
stockc5Z06
nobody....
are the cats in base c5 the same as c5 ZO6?
Old May 5, 2013 | 01:36 PM
racebum's Avatar
racebum
manifolds on the c5z are different. would be surprised if the location was identical. you can try it but i would have a mig welder handy if you need to cut and reweld them in
To catalytic converter
