Clay Bar Review....
Old May 7, 2013 | 10:44 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Clay bar is the way to go, but just something I can't push myself to do. I'll do lots of mechanical things to my Vette getting it up on 4 jack stands, getting all greasy, and even interior stuff, just took apart everything required to get into the dash and gauge cluster to install new LED lights, but for clay bar/waxing, shampooing carpets, I've got a guy up the highway who does all my vehicles, and a wonderful job too......
Kudos to you guys who handle it yourselves......
Old May 7, 2013 | 11:01 PM
GTJim's Avatar
GTJim
I got to do my Z this weekend, hopefully the weather will clear up.
Old May 7, 2013 | 11:05 PM
JETninja's Avatar
JETninja
WA Events Coordinator
Originally Posted by RC000E
My friend just clay bar'd his sti and it ended up dulling his clear coat in a ton of places. I had to take three hours to buff his car to get it back to good. He used turtle wax brand. I use meguiars brand and it comes out fine in the end...no issues.
Then he used a Pro (Shop) Clay meant for special cases of removing tough things like overspray, a consumer Clay like Mothers or Meguires will not do that as long as you use plenty of lubricant...either Detailer or Soapy water...
Old May 8, 2013 | 12:02 AM
jdot's Avatar
jdot
Soapy water? What type of soap is best to mix with the water if you run out of the lubricant and don't have access to anymore right away?
Old May 8, 2013 | 12:08 AM
JETninja's Avatar
JETninja
I've clayed a few times after washing the car before a full rinse, after a quick clay of the upper surfaces then I take the wash mitt to it again...works great in a pinch. I tend to use Meguiar's Gold Wash...
Old May 8, 2013 | 09:10 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I did my 80 a few years ago , it's a pain but I think it's worth it
Old May 14, 2013 | 08:23 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by James2002z06
If you think that your Vette is Clean , then think again cause it not ....
In my case James.... Your wrong...
I clay bared my car last night. First time I have clayed it since I got it new 9 years ago.
I got VERY LITTLE of anything off on the clay. The Clay moved across the paint like a frozen hockey puck on ice every section I went to.
My car does not see rain though and is always garaged, so maybe that was why.
Toque
Old May 14, 2013 | 08:45 AM
chasboy's Avatar
chasboy
Oldtimer
Just a bit of dish detergent in a spray bottle of water.
Old May 14, 2013 | 09:17 AM
djmlax89's Avatar
djmlax89
I use the Meguiar's clay bar kits, they come with the quick detailer spray for lubricant and work pretty well. I'm sure any decent car wash soap and water mixture would work also.
Old May 14, 2013 | 09:45 AM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Toque
I can confirm that. A car that has been thoroughly clayed, polished, and sealed, and driven and stored in 'clean' environments will not pickup much contamination. Once you get through this initial process it is pretty easy to maintain with either washing or wiping down with detail spray after driving it, then the occasional glaze or wax.
Getting the contaminants off as soon as possible will keep them from 'sticking' and settling into the finish. Getting the bugs off while they're still juicy, rather than letting them dry for a while on the paint, is easier and prevents staining. When I put the Vette away, I start with a quick dustoff with compressed air, and then wipe down with detail spray and two microfibre towels. I may do a touchup with the clay bar here and there but overall the car's finish still stays clean and smooth. I haven't actually washed the car yet. However, I like the idea of claying before rinsing off the soapy water if I ever do wash the car. Yeah, I know - it's a seasonally driven garage queen and I'm pretty **** about it.
As can be expected, my wife's 2011 Honda daily driver loads up a clay bar pretty quickly every time her car gets the treatment. However I feel it's worth it to keep up with it - it takes a full day to clay, polish and seal with a machine polisher.
Old May 14, 2013 | 01:09 PM
bajajohn's Avatar
bajajohn
I used the Mothers clay bar kit on the Vette last weekend. Turned out great. Makes the paint feel like glass.
Old May 14, 2013 | 02:41 PM
gun5l1ng3r's Avatar
gun5l1ng3r
Originally Posted by JetMechZ16
Just wondering if anyone with a Commemorative Edition has used a clay bar on the stripes and if it worked well on them?
I got a little bit of the clay bar on the edges of the stripes and managed to wipe it away with a cloth w/o any visible damage/peeling.
I am definitley going to be more careful going forward since learning about the stripes no longer being available.
PS-I did NOT claybar the actual stripes, only the paint. I would recommend not using wax/clay on the stripes, just in case...
