C5 minimum safe rotor thickness
Old May 7, 2013 | 01:18 PM
thedudeman's Avatar
thedudeman
Default C5 minimum safe rotor thickness
Hello, I need to know the minimum thickness for C5 rotors. I want to be sure the rotors are still thick enough to use. I have a custom set on the front (no idea what they are) and stock on the rear. If I need to, I will replace them. Thanks.
Old May 7, 2013 | 01:33 PM
maxx2200's Avatar
maxx2200
If someone doesn't chime in, the spec should be stamped on the rotor hat.
Old May 7, 2013 | 02:40 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Oh my, we've hit a new low.....
Old May 7, 2013 | 04:32 PM
Kevin Kuse's Avatar
Kevin Kuse
1999 Chevrolet Corvette V8-5.7L VIN G
Vehicle » Brakes and Traction Control » Disc Brake System » Brake Rotor/Disc » Specifications » Minimum & Discard Thickness
Front
New 1.260 in
Minimum 1.205 in
Discard 1.190 in
Rear
New 1.020 in
Minimum 0.980 in
Discard 0.965 in
Old May 7, 2013 | 06:17 PM
Bill McCassey's Avatar
Bill McCassey
FWIW, I cut my rotors and the first time I hit them hard they warped bad. Save yourself the hassle and just buy a good set.
To C5 minimum safe rotor thickness
