Key prices?
Old May 7, 2013 | 03:00 PM
mikeyrko's Avatar
mikeyrko
Default Key prices?
I went to 3 different places today trying to get a copy of my key made,
Every place could not help me the last one said try a locksmith but its going to run me $80.
How much have you guys paid?
And could I get a copy made without the chip to get in the door?
Old May 7, 2013 | 03:25 PM
tomikem's Avatar
tomikem
Ebay $5-$10. Just make sure you have the correct resistance. See google for instructions and resistance values.
Old May 7, 2013 | 03:31 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Try looking at just buying the blank and then letting someone cut it to match your current one for a couple bucks.
Eckler's has them for $15.99 at the following link.
http://www.ecklerscorvette.com/steer...s.html?reset=1
Im sure other places can be found for similar pricing.
The Vats pellet in the key is simply a resistor.
The code # and the resistance values are in the table below that I found somewhere on this forum. Measure your current key to find out which one is right for your car.
1 392
2 523
3 681
4 887
5 1.13k
6 1.47k
7 1.87k
8 2.37k
9 3.01k
10 3.74k
11 4.75k
12 6.04k
13 7.50k
14 9.53k
15 11.80k
Good luck.
Old May 7, 2013 | 04:07 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
I bought two keys via Amazon for $15 and took them to Home Depot for cutting. They didn't charge me at all for the cutting.
Old May 7, 2013 | 05:51 PM
mxz800's Avatar
mxz800
I first went to the dealer they were useless, they could order the key for $75 but couldn't cut the key on their prehistoric key machine. I went down the road to a hardware store that also has a locksmith service. The guy slide my key into a machine to check which resistor my key had, then $16 bucks later I was all set. I didn't want to wait around to have it mailed, then with my luck it be the wrong resistor, then see if someone might cut it for me.
I never had any luck trying to find a 5 dollar solution to a 10 dollar problem, I would rather just deal with the locksmith.
Old May 7, 2013 | 06:07 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
A local locksmith here will sell you the key with the correct ohms and cut it 15 bucks.
Old May 7, 2013 | 07:26 PM
bobsride's Avatar
bobsride
I had the local locksmith cut it and I walked outside and tested it. Perfect $14.95 later and than got a extra fob on e-bay. Now I have a third key just in case. Less than $20.00 got piece of mind. Can't be too prepared, I am so happy that I did not second guess my self with the extra house insurence. We got hammered with Sandy and we everything covered and replaced.
Old May 7, 2013 | 09:24 PM
o2bnkc's Avatar
o2bnkc
I did the same thing.
Old May 7, 2013 | 09:57 PM
As mentioned above, a local locksmith should be able to provide the key and cut it for you. Or buy one off the auction site (correct resistance value) and have it cut locally.
Old May 7, 2013 | 10:10 PM
VtVette's Avatar
VtVette
C5's still have VATS??
Is it the same VATS as the C4 had or, is it the later Passkey/Passlock?
Old May 7, 2013 | 10:58 PM
mikeyrko's Avatar
mikeyrko
Thanks I will go to a local locksmith and see what happens.
I found a video that showed me how to check the ohms, I will post later for anybody who might need it.
I wonder why nobody is making keys with the corvette logo on them?
Old May 7, 2013 | 11:13 PM
thmehr's Avatar
thmehr
I had the same issue. I found a video on the internet that tells you how to use a ohm meter to test for the resistance. My ky turned out to be code 8 based on the ohms. I purchased one off ebay and took to my local hardware store. Bingo, I know have a spare key.
here is the video
I used my $5 volt meter to do it.
Old May 7, 2013 | 11:18 PM
mikeyrko's Avatar
mikeyrko
here is the video
How to Read a VAT Key - YouTube
Thanks that's what I was going to post.
Old May 7, 2013 | 11:21 PM
Mr.Bill's Avatar
Mr.Bill
GM trade mark, That will up the price 100% if not more.
To Key prices?
