Tire Size
Old May 9, 2013 | 07:47 PM
MemphisTenn's Avatar
MemphisTenn
7th Gear
Default Tire Size
I bought some new wheels and was wondering what size tires to run now?
The new wheel sizes are 18x10.5 in the rear with 17x9.5 in the front.
Old May 9, 2013 | 09:37 PM
MemphisTenn
7th Gear
Front Wheel offset: 54mm
Rear Wheel offset: 56mm
Old May 9, 2013 | 10:16 PM
ParisTNDude's Avatar
ParisTNDude
The wheels size and width are the standard Z06 size and I think the offset is the same as well. Find out what size tires Z06s use and you're good to go. Post PICS and someone will know what you have.
Incidentally, do you ever make it out to Memphis International Raceway for Test & Tune. There's a pretty big bunch of Camaro and Corvettes from West TN that go regularly. See you there.
Old May 9, 2013 | 10:22 PM
jcsperson's Avatar
jcsperson
NC Events Coordinator
Chevrolet put 265/40/17 front and 295/35/18 rear on those size wheels which are stock Z06 sizes. Some manufacturers no longer make the 265 front, so 275/40/17s are an easy bump up.
Old May 10, 2013 | 09:55 AM
phil hunter's Avatar
phil hunter
I have the same wheel sizes. I'm running 275/40/17 up front. 305/35/18 in back.
Phil
Old May 10, 2013 | 01:25 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
265 front/305 rear for me
Old May 10, 2013 | 08:37 PM
KingTut's Avatar
KingTut
255-45-r17 & 285-40-r18
Old May 11, 2013 | 10:45 PM
jmac2354's Avatar
jmac2354
Phil
These are sizes I ran on my stock Z wheels, no complaints, multiple vendors to accommodate
To Tire Size
