C5 oil pressure sensor replacement
Old May 9, 2013 | 09:51 PM
larry21957's Avatar
larry21957
Default C5 oil pressure sensor replacement
I researched the topic in the tech section, used the tech on not removing the intake manifold to replace the sensor. It went good. Need to use 27mm deep well (not impact socket) 1/2 in., short adapter to 3/8 and joint, long extension. The hardest part was using the coat hanger to get the connector off. The new one, I filed down connector catch down a little to make it easier the next time. This was on my new purchase, 01 Z06, 76k miles, one owner.
This is added to my other vets, 78,81 and 91.
This forum is great, a lot of great info and members.
THANKS
Old May 9, 2013 | 10:06 PM
AntsSilverC5's Avatar
AntsSilverC5
I used a similar method...got flamed a bit on the forum for not yanking off the intake manifold and doing it "the right way", but found out this sensor goes out fairly often in these cars. Popping a small hole (which ends up being covered by the plastic below the windshield wipers anyway) and the A&A kit/intake, etc. I got on the car just seemed like too much to do for something so small. Will be easier to do if/when it needs to be done again too.
Old May 9, 2013 | 10:42 PM
larry21957's Avatar
larry21957
I used the tech that went behind the intake, not making the hole method.
Old May 10, 2013 | 12:32 AM
racebum's Avatar
racebum
you guys need to post pics of what you're talking about. i picked up a sensor the other day and the manifold looks easy to remove, but, if there is an easier method.....
Old May 10, 2013 | 12:53 AM
richard emmanuel's Avatar
richard emmanuel
Default lot easier
I did it the hole method a few years ago also. Using the liscense plate so I would not cu to deep. It worked good and fishing the wire out with the hanger was a brezze.
Richard
Old May 10, 2013 | 01:14 AM
dblerman's Avatar
dblerman
The first time I ever had to remove my intake was to replace the oil pressure sender, it took me about 25 minutes to move the intake forward, 5 minutes to replace the sender, and about 20 minutes to re-install the intake.
The 2nd time I removed my intake, it took me 15 minutes to COMPLETELY remove it from the car. It would have taken me 10 if I hadn't forgotten to grab the clothes pins for the rear bolts and had to run back inside to find them.
After you pull the intake you'll wonder why anyone would try any other method for replacing the sender
Old May 10, 2013 | 01:29 AM
corvettedaddy11's Avatar
corvettedaddy11
U better get a relocation kit ive replaced 2 already im not taken that intake off again..!
Old May 10, 2013 | 01:39 AM
WICKEDFRC's Avatar
WICKEDFRC
Ahhh yes.....The Oil Pressure Sensor....Ranks right up there with replacing the Hazard Relay Switch..... or a clutch Master Cylinder.
Old May 10, 2013 | 02:18 AM
Mike Yeager@Eastcoast Performance's Avatar
0Mike Yeager@Eastcoast Performance
Former Vendor
Hey Guys,
Check this out...we can help, and as all of you know who have ever dealt with Eastcoast Performance-Corvettes, we ONLY do it the right/correct way, No cheap junkie china made items from us, ONLY the Very BEST, USA made...
http://forums.corvetteforum.com/c5-g...post1583861751
Old May 10, 2013 | 02:40 AM
AntsSilverC5
I originally tried to swap mine without removing the intake with a concoction of extentions, elbow joints, deep sockets, etc. on my ratchet, as I had seen it swapped without needing to remove the intake on youtube. After tons of time that didn't work. I'm always a fan of doing stuff the 'right' way...wish I knew about this relocation kit when I first had the problem. Did the hole method. No one can see it and it doesn't affect anything (from what I can tell), but I know there will be those that will flame the idea of doing ANY type of cutting/drilling on a C5 no matter where. For the record, I sorta wish I did the relocation before I had the problem.
Old May 10, 2013 | 09:01 AM
xdmikey's Avatar
xdmikey
Is the sending unit a mileage or a time thing? Or a luck thing?
My 97 has just over 64k. Should I go ahead and buy the relocation kit in advance?
Old May 10, 2013 | 09:11 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I have removed my intake a couple of times and it is really easy, I would never fight changing the sender as some have done, I bet I can have the intake off in less than 15 minuets. The last time I made a relocation kit and now my sender is under the drivers FRC, Really easy to get to now.
Mr.Bill
File Type: pdf
Old May 10, 2013 | 02:18 PM
Johnz02Z06's Avatar
Johnz02Z06
St. Jude Donor '14
I did it without manifold removal...maybe not the "right way" but worked for me
Old May 10, 2013 | 02:47 PM
racebum's Avatar
racebum
luck thing
some have lasted a month, some have lasted since the car was built
which literally makes no sense. no part should have that wide of a useful life
Old May 10, 2013 | 03:36 PM
maxx2200's Avatar
maxx2200
Yeah buddy!
Old May 11, 2013 | 12:43 PM
larry21957's Avatar
larry21957
[QUOTE=larry21957;1583860311]I researched the topic in the tech section, used the tech on not removing the intake manifold to replace the sensor. It went good. Need to use 27mm deep well (not impact socket) 1/2 in., short adapter to 3/8 and joint, long extension. The hardest part was using the coat hanger to get the connector off. The new one, I filed down connector catch down a little to make it easier the next time. This was on my new purchase, 01 Z06, 76k miles, one owner.
THANKS[/QUO
I try to add a photo of tools I used,
Old May 11, 2013 | 12:45 PM
racebum's Avatar
racebum
is there any correlation between long tubes and these failing? was just thinking that long tubes shorten the life of a stater by a substantial amount. have these fast sensor failures been from a similar reason?
To C5 oil pressure sensor replacement
Old May 11, 2013 | 12:59 PM
larry21957's Avatar
larry21957
THANKS[/QU
Old May 11, 2013 | 01:09 PM
larry21957's Avatar
larry21957
THANKS
I can't figure out this picture stuff!!!!!!
Old May 11, 2013 | 03:21 PM
TwoSmoke's Avatar
TwoSmoke
Here is the thread a member did on replacing the sender the easiest way.
http://forums.corvetteforum.com/c5-g...post1583043214
