I tried to add mine, does it take a while for it to show up? It could also be Opera browser, sometimes pages like this get a little jiggy. I'll switch to Firefox to add it if needed.
It should be immediate. I just added and deleted one with Pale Moon and it was. I don't know about Opera, never used it. Try again or maybe try FF and see if that works for ya.
Edit: Actually, I just looked and you're showing in Dayton, Ohio
Even after I gave it latitude and longitude? Just tried it in Firefox, got the same.
It seems to think that Dayton Oregon doesn't exist, I'm done fiddling with it for a while, I have little patience for apps that are seemingly poorly written.
I see you in Dayton, Ohio. Try going to "View -> Show List" and then scroll down to the bottom - you should see your handle. Double click that and your info pop up and marker should show up - it did for me
I finally got it to stick by using the click map option, then not mentioning Dayton in any way. The script assumes any Dayton address, even with GPS coordinates indicating otherwise must be in Ohio. Now, if I try to add an address it refuses and says they can't find that address
I'm leaving it alone
