Instrument Cluster Lights Problem
Old May 15, 2013 | 11:49 AM
huskerhank's Avatar
huskerhank
Default Instrument Cluster Lights Problem
Here is my problem. The instrument cluster lights do not come on with the headlights but they will when you shut it off and pull the key. They were working and I had a bezel come off so GM mechanic fixed it. The brightness **** is turned up, the DLR's and tail lights also work. It really confuses me since they were working and will work after the key pull and door open. Any help is appreciated. Will take back but if it is something simple, will do myself.
