breather issue / coolant temp low code
Old May 21, 2013 | 06:27 PM
teach79's Avatar
teach79
Default breather issue / coolant temp low code
just bought a 02 z with a tony mamo special in it , love the car but my valve cover oil breather leaks onto the header when i stand on it is there a sock or foam i can put around it . it is a k&n standard breather ??? does anyone from here know of mike norris from iL , he tuned the car a few times since the car was built and i have some general questions that maybe you guys can answer 1 the motor is super finicky when cold like it is rich/fat , 2 throws low coolant temp code all the time can that be shut off ? , 3 when warm it seems the car still runs way rich like maybe there is a bog at the low end of the rpm but definetly clears out by 2,300 rpm ? just looking for ideas thanks .
