[Z06] Tire fitment chart
Old May 22, 2013 | 06:49 PM
rled's Avatar
rled
Default Tire fitment chart
Can someone point me to a fitment chart that shows wheel and tire combos that will fit a stock height Z. I would like to put the same size tire front and back on a 02 . I have searched this forum with several key phrases and no luck yet.
Old May 22, 2013 | 10:24 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Look up toque , go to is home page he has a tire size guide there. Might be what you are looking for.
Old May 23, 2013 | 11:49 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
You can't put the SAME size tire on the front and rear of these cars.
The rear tire diameter MUST be larger than the front by at least 0.5".
You will confuse the car's Active Handling, and Traction control if you were to put on the same size tire on the front and rear.
I have a guide to properly sizing your tires on my web site.
www.ToqueZ06.com
How to Determine the correct "Tire Size" for new wheels on a C5 and C5 Z06:
Hope this helps !
Toque
Old May 23, 2013 | 02:01 PM
Hitman227's Avatar
Hitman227
I've checked Toque's numbers, they are in line with what should be implemented for sizes. For tires I don't have any information on my site, however you can check it out if you are interested to verify what I run in regards to the tune on the motor.
Old May 23, 2013 | 07:48 PM
rled's Avatar
rled
Thanks Toque. i didn't know that about the traction control. Thats interesting. I would like to know how that system works. thanks again
To Tire fitment chart
