Tire size?
Old May 23, 2013 | 12:22 PM
C5Conrad's Avatar
C5Conrad
Default Tire size?
I have an 01 Z06 with the stock 17 + 18" Z06 wheels...
I'm going to upgrade to C6 Z06 wheels in the sizes 18x9.5 and 18x10.5.
What tire sizes would be best to keep my MPH about the same and not mess with the active handling?
Pictures also help if you have this set up.
Thank you.
Old May 23, 2013 | 01:56 PM
C5Conrad's Avatar
C5Conrad
Wow that helped a lot!
Tire sizes I think I'll go with (just need to make sure these are common tire sizes)
285/35/18
315/35/18
MPH will be off 1.2mph in the front and 1.3mph in the rear. This shouldn't be a big deal I'd assume.
Old May 23, 2013 | 02:01 PM
C5Conrad's Avatar
C5Conrad
Just posting these links for my own reference.
http://www.rimsntires.com/specs.jsp
http://www.z06vette.com/forums/f142/...-sizes-119671/
http://www.oewheelsllc.com/Wheels_3/...Wheels-Black_3
Old May 23, 2013 | 03:24 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
285/35/18
315/35/18
315 seems like a large tire for a 10.5 wheel.
Old May 23, 2013 | 10:04 PM
C5Conrad's Avatar
C5Conrad
Ah ok. Maybe 275/35/18 and 305/35/18 would be better?
Old May 23, 2013 | 10:26 PM
Bent98c5's Avatar
Bent98c5
Do that or like a 265 35 18 in front.
Old May 23, 2013 | 10:40 PM
Zr-1Mike00's Avatar
Zr-1Mike00
That would have been my suggestion.
I have a similar setup: C6 Z06 Repros in an 18 x 9.5 / 19 x 11 stagger.
275/35/18 in the front and 305/30/19 in the rears. If you went with 315's I believe you would be a bit beyond the fenders..
Old May 23, 2013 | 11:12 PM
C5Conrad's Avatar
C5Conrad
That would start to mess with my traction control/active handling.
Ok thanks car looks good!
Old May 23, 2013 | 11:15 PM
Zr-1Mike00's Avatar
Zr-1Mike00
No doubt! And thanks to you.
Old May 23, 2013 | 11:16 PM
racebum's Avatar
racebum
get the 19" rear you'll have way more options
Old May 23, 2013 | 11:59 PM
Mr.Bill's Avatar
Mr.Bill
I have 18x9.5 front and 18x10.5 rear and I run 265-35-18 and 295-35-18 tires and fit great with no issues.
To Tire size?
