I mostly agree with this sentiment. However, I'm still thrown by the OP's high torque readings. Even if he was making 385 ft-lbs with just bolt-ons (which is already on the high side), I don't see a FAST and streetable clutch getting him to 410+ ft-lbs. Thoughts?
Can't speak to the torque as the FAST really only had an effect on the stock (stock exhaust) LS6 from 5,000+.
This doesn't show how the FAST acts on an engine with headers though. The lightweight clutch certainly did have an effect on the torque, as evidenced by this before and after article. So even if the numbers are still somehow inflated, there's not a doubt in my mind that he'll put down over 400whp no matter where he goes with torque that'll nearly match it.
I'm not really a dyno guy especially after watching my 03 Cobra lay down 420 and my friend with more mods lay down almost 480 the same night and then the next morning at the track I went 11.40s @121 and he went 11.70s @120.
The thing that has me wondering about his power is that someone said that he went 128 at the track. That MPH is huge for a bolt on Z. BUT,,,,, his MPH does match my mph with my Cobra at the same power with the weight difference. Makes me wonder if it does have something else done to it that he doesnt know about.
OP Who cares what the dyno says,your car went 128 MPH. Thats all I would care about.
I'm with you on that one. I'm hoping to get over to MIR sometime soon for a test and tune session. When I do, I'll post my timeslips.
FWIW - I don't believe there's been a cam installed. I'm the 3rd owner of the car and see the previous owner every few weeks at the local car show. He is unaware of any mods other than what he installed. I'm pleased with the numbers and am looking forward to seeing what it can do in the 1/4 mile.
I was pretty harsh on your numbers on your last thread. I think you have 1 hell of a car, I am really curious (as is everyone else) about your TQ numbers They are huge, too huge. I have your exact mods on my car, minus the FAST and the brand.
It is really fast. I have the Textralia OZ700 clutch and flywheel, LG Pro with high flow CATS and a Corsa Extreme exhaust, HS Trunion upgrade, Donaldson Blackwing air intake and 18/19 iforged rims...It is a light drivetrain.. I would be curious to see my numbers but it is not worth 80 bucks to me.
( I am sure you all know) Torque is generated from the downward force on the crank shaft from TDC to the horizontal centerline of the crank shaft. So in reality the length of your stroke determines TQ, and a cylinder bore and larger pistons would really benefit you more in the HP range than TQ. So were I to speculate on the mysteries of your engine I would lean more towards an aftermarket crank...or even best case a forged rotating assembly, it is not worth tearing your engine down to figure it out.
All I am going to say this time about your car is, you have a mystery part, Whish I knew what it was so I could get it LOL nothing wrong with that!
Cam Lobe separation is more of an impact, if they put a longer stroke crank in, i THINK you would need to clearance the block and use new pistons as well because of the change in ring position, more stroke can increase TQ , but a cam is a less intrusive upgrade vs pulling the engine,
OP has a FAST intake AND a lightweight clutch assembly. Everybody seems to be forgetting that when they post up their own cam only numbers with stock intake and stock heavy clutches. With stock exhaust, the FAST is good for 15whp which puts the OP at or over 400whp (notwithstanding the additional gains realized by the FAST with headers) before the clutch which is at least 10whp by itself. If we all agree that 385whp is reasonable before those 2 then the numbers don't seem all that unrealistic for a stock cammed engine. All these cammed numbers have torque lower than hp, whereas the OP's torque is pretty much there with the hp. I'm just sayin'. . . this is how I'd been planning to mod my car anyway, I'm glad to see the numbers are there.
I know I'm late to the party, but this post is exactly the way I see it. There is a guy on ls1tech with a ls6 in his z28 and is putting out 420+rwhp with the stock ls6 cam and heads. The key as mentioned here and earlier is the aftermarket clutch which can easily be worth 10-15 rwhp. This fast intake also is an easy 15-20 rwhp gain too. Remember, alot of people with cammed ls6 z's usually skip these mods, and the same for bolt-on cars too. Heck there was one guy with a ported tpis 90mm ls6 intake that put down 20rwhp with a bolt-on c5z. He had a before and after dyno, both times tuned. So a fair comparison.
Another thing I wanna say too, is tuning is overrated on these cars with bolt-ons. I saw a guy run my old bolt-on z on the dyno over 10 times and was only able to get about 7hp. This was with headers, cai, and borla stingers. I was at 377 untuned on 91 oct. gas and the tuner tried all kind of timing and a/f changes to make more power. Didn't make anymore power until he reduced the knock sensor activity (they kept pulling timing). Ended up with 385rwhp and 377 rwtq on crap cali gas. I eventully got rid of the cats and it easily felt like anothe 10hp at the wheels. But that's not a known fact.
So a lightweight clutch will free up 10hp to the rear wheels? Don't think I have ever heard that before on any sports car.
In the same way a lighter wheel means more horsepower to the wheels because of less unsprung weight, so to does a clutch.
This isn't really "adding" horsepower - it is reducing the inefficiency of the motor at putting horsepower to the ground. We all know rear wheel horsepower is less than the actual horsepower the engine puts out - lighter components like flywheels or wheels reduce that inefficiency.
Yes I understand all of that, thus why I said "free up" horsepower. But I haven't heard of 10hp gains from only a clutch. Maybe 2-3 at most.
