Static from radio
Old May 26, 2013 | 12:34 PM
Linusmcduffy's Avatar
Linusmcduffy
Default Static from radio
I have a constant hum comming from the rear speaker. When the radio is on it sounds ok until i push the brake or use the turn signal. Then it just goes to loud static. I hate that i cant use my radio. I just mainly use CD's because there is no issue here. I have not made any modifications to the audio system. Does anyone have any idea what may be causing this. I dont want to tear anything apart because i am unsure of what I am doing. It sounds like a bad ground to me...thank you for any help
Old May 26, 2013 | 12:44 PM
calvins's Avatar
calvins
Oldtimer
I would agree, it does sound like a bad ground. Check the stickies and the links in the "buying a ...." post. In any download that includes the "Tech" documents there's a document describing the ground points on a C5.
As for getting to the radio, I just replaced my stock head unit and will a bit of help it's really not bad.
Edit: Adding link to sticky thread
http://forums.corvetteforum.com/c5-g...ion-files.html
Old May 26, 2013 | 11:04 PM
Linusmcduffy
Thanks for taking the time to post a response...I will at some point be replacing the radio with something newer. I am sure that this radio was the bomb in 1997 but sot so much now...
To Static from radio
