Where to put jack stands?
May 28, 2013 | 01:55 PM
St. Jude Donor '13
I assume under axles on rear end, but not sure on front. If jacking up to remove a tire, is it OK to set stand next to jacking point on frame rail?
May 28, 2013 | 02:17 PM
St. Jude Donor '09, '13, '15
May 28, 2013 | 04:29 PM
Quote:
Originally Posted by
tacman
I put the jack stands where the light green points are in post #2.
May 28, 2013 | 08:48 PM
Oh 2 Fun, did you just roll that jack under your pipes or did you have to drive up on blocks to get enough clearance?
May 28, 2013 | 10:12 PM
xdmikey
Two things....
1. Low profile jack from Harbor Freight
2. Look closely and you can see the 2x12 boards I drove up on.
I cut them at an angled "V" so the center of the tire catches the leading center edge and they don't scoot while yer driving up on them.
May 28, 2013 | 10:25 PM
Here's an older pic that shows the boards....not a big deal but it makes the move smoother......IMHO.....
Ha....no center exhaust plate in this pic either...
May 28, 2013 | 11:05 PM
Got it
Thank you sir.
