xm antenna
Old May 28, 2013 | 05:43 PM
flags97's Avatar
flags97
Default xm antenna
Those of you that have the portable xm units, where do you put your magnetic antenna, I put mine center of windshield, but not satisfied with that because its not completely attached, can anyone think of better spot, I was thinking drivers side outside pillar. Ideas???
Old May 28, 2013 | 05:57 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I set my sat antenna and nav antenna in the left and right bottom pillers next to the windshield. On the inside.
One on each side.
Old May 28, 2013 | 06:34 PM
c4cruiser's Avatar
c4cruiser
I have a Sirius antenna sitting on the top of the rear crossmember. It's magnetic so it sticks there out of sight. I ran the cable through the vent opening on the driver's side rear corner in the storage area.
Simply remove the left side tail light housing and the crossmember is easily accessible.
Old May 28, 2013 | 06:54 PM
matthewlfd's Avatar
matthewlfd
I mounted mine under the dashboard to the right of where the HUD projector goes. Mounted it to the big beam that goes from side to side under the windshield. Works great and is 100% hidden.
Old May 28, 2013 | 06:55 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
I have a siriusXM antenna (SV200) routed to the back of my '01 'vert. It's fed through the back wall of the trunk area (along with some other wires for my backup camera) and 3m double-sided taped to the outside of that back wall, roughly between the license plate and driver side tail lights. I used some of that shiny aluminum tape to secure the wire to the panel as well so it wasn't hanging around. I've had no issues with reception so far.
Old May 28, 2013 | 09:01 PM
Ron C!'s Avatar
Ron C!
I have mounted them on the rear cross member behind the tail lights, on the dash by the passenger side pillar and my latest one is on top of the fender well in the back of my Z. Still deciding about the fender well, I have had some reception issues in other locations.
Old May 28, 2013 | 11:34 PM
jrose7004's Avatar
jrose7004
I put mine on the passenger side at the corner of the windshield.
Old May 29, 2013 | 07:16 AM
flags97's Avatar
flags97
Default xm antenna
One on each side.
And you have not had any problems with reception?
Old May 29, 2013 | 09:17 AM
Mr.Bill's Avatar
Mr.Bill
None at all.
Old May 29, 2013 | 05:48 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
One on each side.
i did the same. one under each of the A pillar covers at the windshield. it's all plastic so there is no interference and they work perfectly so far (and it's been almost 2 years since i swapped my system out for a double din nav/dvd pioneer system (than you dennis at doubled mods!!)
Old May 29, 2013 | 06:52 PM
flaagan's Avatar
flaagan
St. Jude Donor '12
One on each side.
I'm tempted to reroute mine to mount up on my gauge pod pillar, though I think the reception problems I have near home is due to our house's location. Need to find a local friend with a similar antenna and see what their reception's like.
To xm antenna
