Automatic climate control question.
Old May 29, 2013 | 03:58 PM
Glenn25's Avatar
Glenn25
Default Automatic climate control question.
Just bought a 2000 torch red coupe and it has the auto climate control, seems to be working fine just wondering when I turn the passenger side control **** if the temperature on the display is suppose to change like it does in my 2004 silverado.
Thanks.
Old May 29, 2013 | 04:43 PM
calvins's Avatar
calvins
Oldtimer
Nope. Just makes it warmer or cooler than the driver has it set. I'm not positive but I think the offset is plus or minus 5 degrees F.
Old May 29, 2013 | 04:44 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Thanks.
No, the left control is what changes the temp in whole, The right **** will adjust the temp a little up or down, But not on the display.
Old May 29, 2013 | 07:56 PM
m6 c5's Avatar
m6 c5
I had heard it was something like 10% but either way its not much of a difference but enough to make your passenger a little happier
To Automatic climate control question.
