Detailing questions
Old May 29, 2013 | 08:18 PM
Maineah's Avatar
Maineah
Default Detailing questions
Has anyone used a random orbital sander with a foam polishing pad for buffing? Seems to me it should work fine, my sander is variable speed.
Does polish work to remove fine scratches in the removable roof panel?
Jeff
Old May 29, 2013 | 08:30 PM
CQRT's Avatar
CQRT
Yes-- lotsa good info - -use "orbital" as a search word . . .
http://forums.corvetteforum.com/c5-g...al-buffer.html
http://forums.corvetteforum.com/c5-g...-secretes.html
http://forums.corvetteforum.com/c5-g...olish-wax.html
Scratch:
http://forums.corvetteforum.com/c5-g...a-scratch.html
works on the roof too . . . .
Good luck !
Old May 29, 2013 | 09:18 PM
RMB97LS1's Avatar
RMB97LS1
Just make sure it's a random and not rotary. You'll burn through your paint in a second if you're not careful.. Good luck and have fun. Those DA's can produce some amazing results.
Old May 29, 2013 | 09:49 PM
Maineah's Avatar
Maineah
Thanks for the links. My question is the random orbital sander essentially the same as a random orbital buffer?
Old May 29, 2013 | 09:51 PM
Kmcoldcars's Avatar
Kmcoldcars
Yes
To Detailing questions
