[Z06] L.E.D Switchback lights HELP!
radioflyer- both are excellent.
1.) They can be a bit tricky to install- It took me a little while to get them seated correctly.
2.) The light color in running light mode- is a bright white- this does look different and creates a contrast if your headlights are stock....which means...
3.) Upgrading the stock headlights to the HID lights- this was pretty easy to do as well- but you will likely have to re-aim your headlights- many sites show how to do this.
4.) Flash pattern is much faster than with the stock bulbs- a wire harness will eliminate this.
5.) After all this- you will find that your new bright white lights don't match the interior lighting- so you might want to get the interior led light kit.
In the end- very worth it!!!
thanks for the info
http://www.shop.radioflyerinnovation...D-bulb-025.htm
You will also need the Hyperflash Bypass harness to maintain the factory turn signal flash rate. (you can get the switchback bulbs at a discount if you get both the harness and bulbs)
http://www.shop.radioflyerinnovation...arness-027.htm
We also have interior LED upgrade kits:
http://www.shop.radioflyerinnovation...te-set-037.htm
As well as much more!
Have a look around and shoot me an email. I'll be happy to work you a package deal price!
