[Z06] Autotap questions
1) What sampling rate are you getting. I am sampling about 12-14 parameters per second
2) How come some of the parameters are listed twice in the selection areas? For example - STerm Fuel Trim B1(%) is in there about 3 times. Is this so you can check a parameter more than once per "scan cycle". I logged some data and put STerm Fuel Trim B1(%) in there twice, one value right next to the other. The values recorded in these two fields were very different from each other, that is disturbing. See this file:
http://www.rbartick.com/cf/l3.csv
3) Is there a parameter for pulse width?
4) How is this thing calculating the WOT A/F ratio? My software (version 1.11 from the WWW site) is logging WOT ratios, but I thought the stock narrow band O2 sensors were not able to do that.
5) My version of Autotap is pretty stable, but it crashes quite often if I stop a log session and then try to start logging a new session. If I close Autotap and then reopen it before starting my second log it will not crash. Anyone have this problem?
