I need help ppl how to make my c5 6 speed fast on a low budget
Hi my. 00 c5 6 speed stock wit no cats or exhaust straight pipeing and sum 18". Drag slicks motor has only 93k miles on it check engine light on due to no cats. Took it to track and my best time was 13.266 @ 104mph. I'm new yo vettes so idk if that's fast or slow for. My vette and also do I loss power running wit no cats?? And no exhaust ?? And check engine light on?? Can sum one please tell me how to at least hit low 12s wit out nitrous or turbo set up.,
Received 1,762 Likes
A good start would be to read the codes, and find out whats going on with the engine. For exhaust, do you have headers or just the stock manifolds? Most of the low cost mods would be CAI, Headers, Intake, then a Cam and tune. Not that all of these are cheap, but it seems to be a common progression. You also want to make sure the brakes and suspension are working well before adding power. Nitrous would probably give the most band for the buck.
Yeah the codes is the o2 sensors due to no cats they get dirty I guess ... I have stock manifolds so do I loose hp running straight pipes all the way to the tips?? No muffler ?? I have erased the check engine light and it seems to run way smoother and stronger wen check engine light off
Location: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
Low 12's is attainable without juice or FI in a C5. A good CAI,decent heads,cam swap,throttle body and intake,good headers for starters. Low budget? Well...my advice? Shop around here for awhile and you'll be amazed how much you can save buying parts from other members. Some items will be hard to come by cheap or at deep discount for various reasons. At that juncture,sometimes you just have to step-up and pay for it when you need it. A good tune and dyno will give you a basement figure what kind of RWHP your putting down with your car now,so it gives you an idea what you'll need to achieve your performance goals. Good luck
Cold air, long tubes, gears, tune and slicks will get you mid 12's if you can drive. If you can drive means that with a 6 speed it's a little harder to be consistant and get a good launch! no offence to stick drivers, sticks are great but less forgiving than an "auto".
You know when I stop and think about this question , it's the same one that's asked by new or younger owners ...I have no room to talk mine is fast ...people just enjoy your f..king car
Why do you have to go more than 85 mph there is nothing to prove to anyone , take car of your car man
Ok wat kind of gears?? And wat is a good programmer tuner??
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
I know you said "low budget," but what's a low budget with these cars especially if you're looking for horsepower (Nitrous (wet), yea, but?), can you give a $ amount of low budget?
