Weird
Old Jun 4, 2013 | 06:56 PM
Canadaboy's Avatar
Canadaboy
Default Weird
So I went and filled the tank up with gas and headed to pick up my new exhaust system. Now about 15mins in my gas gauge tells me I am out of fuel. I stop about 45 mins later get back in the car start it up and it works the rest the way home. Anyone else have this happen and if so whats going on?
Old Jun 4, 2013 | 07:01 PM
andrec10's Avatar
andrec10
One Word....Techron!
Old Jun 4, 2013 | 07:02 PM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Almost a must-do additive.
Old Jun 4, 2013 | 07:04 PM
Canadaboy's Avatar
Canadaboy
ok new to this what do you mean techron?
Old Jun 4, 2013 | 07:06 PM
maxx2200's Avatar
maxx2200
Fuel additive. Chevron Techron. Can be found at local parts stores. A search may give you more complete information.
Old Jun 4, 2013 | 07:11 PM
Most likely your fuel sending units have some sulfur build up on them and it is causing some erratic readings by the fuel gauge. The use of some Techron additive to the gas has worked for others to help clean off the sending units and return the gauge to normal operation.
Old Jun 4, 2013 | 07:15 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
There are two types, injector cleaner, and fuel system cleaner....you want the latter.
Old Jun 4, 2013 | 08:06 PM
shady weezul's Avatar
shady weezul
I had the exact same problem in mine and a large bottle of Techron fixed it.
Old Jun 4, 2013 | 08:14 PM
cor66vette's Avatar
cor66vette
Old Jun 4, 2013 | 08:22 PM
Z06-FIX's Avatar
Z06-FIX
Buy one, get one right now at Auto Zone.
Old Jun 4, 2013 | 11:07 PM
jdot's Avatar
jdot
Originally Posted by cor66vette
I had a "check engine light" pop on one day. Added a bottle of Techron and poof it was gone. I did discover later on that my gas cap needed replacing as well when the light came back on.
Old Jun 4, 2013 | 11:35 PM
Kmcoldcars's Avatar
Kmcoldcars
If you buy Chevron gas with the Techron already in it you most likely will not have problems with your gas gauge.
Old Jun 5, 2013 | 01:06 AM
jornahow's Avatar
jornahow
I had the problem soon after buying my car in 2007 and cured it with the additive. Now I almost always use Chevron gas and haven't needed extra Techron.
Old Jun 5, 2013 | 06:32 AM
LoneStarFRC's Avatar
LoneStarFRC
Or Texaco. Same additive.
Old Jun 5, 2013 | 07:08 AM
ZigZag's Avatar
ZigZag
I just picked up a box of 6 bottles at amazon for $51.10. That's $8.51 per bottle if you're interested. Free shipping with amazon prime.
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sea Foam work well too - but either or will help you out from the builup on the sender!
Thanks,Matt
Old Jun 5, 2013 | 07:12 AM
xdmikey's Avatar
xdmikey
What is the recommended usage? One bottle per month, assuming. Four tanks a month?
To Weird
Old Jun 5, 2013 | 07:25 AM
jvette2's Avatar
jvette2
I use a bottle once a month and this keeps my gas guage happy.
Old Jun 5, 2013 | 07:38 AM
LoneStarFRC
Default "Regane" by Gumout
Been reading this product contains the same active ingredient as Techron:
Old Jun 5, 2013 | 10:12 AM
Loby 1's Avatar
Loby 1
Chevron is the only gas I use.
I throw in a bottle of Sea Foam once a year.
