Batterytender/winter storage
Old Jun 5, 2013 | 10:30 AM
ironranger's Avatar
ironranger
Default Batterytender/winter storage
I'm considering using a 1.25 amp Batterytender while storing my 2001 during the winter. Has anyone had any issues with them or heard of any. I am thinking of fires, etc.
In the past I have either disconnected the black cable or started it once a month and let it run for around 15 minutes and moved it a foot or so.
Thanks for ant insight on winter storage!
Old Jun 5, 2013 | 10:37 AM
Loby 1's Avatar
Loby 1
The Battery Tender "Smart Tender" is the best way to go. I have 4 of them and have used them successfully on several vehicles, cars, motorcycles and lawn tractors. They will not only keep your battery charged they will extend battery life.
Just connect it and forget it, no worries.
Old Jun 5, 2013 | 10:50 AM
stevegray04's Avatar
stevegray04
St. Jude Donor '14
Mine is a 1.5 amp from Advance Auto Parts. I've never had a problem with it overheating or otherwise malfunctioning. Other forum members have their favorite brands and I'm sure they will add their posts.
Old Jun 5, 2013 | 04:19 PM
dcandel's Avatar
dcandel
Oldtimer
Mine's from NAPA and is installed permanently next to the battery (previous owner did it). I use it all winter when the car's not being driven, and use it in the summer too when I know I may not drive the car for a couple of days.
Old Jun 5, 2013 | 04:33 PM
Sonny71's Avatar
Sonny71
Oldtimer
I've used the Battery Tender Jr for 3 years with no problems.
Old Jun 5, 2013 | 06:02 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I have an attached garage, as well as an aversion to fires. I store my C-5, as well as a couple of other "family fleeters", during the winter. Every 7-10 days, usually when I'm outside with the snowblower, I hook up my regular battery charger, set at 10 amps, for about 20-25 minutes. So far, meaning the last 25 years or so, I've had no issues.
Old Jun 5, 2013 | 06:18 PM
calvins's Avatar
calvins
Oldtimer
I've been using Battery Tender Plus units for many years on everything from lawnmower, motorcycle, travel trailer, Corvette batteries, etc. I have the "eyelet" BTP connectors mounted on the front posts of the Corvette battery and if I'm not going to be driving it for a more than a week, it's plugged in.
And they've all been on BTP's for winter storage. The question isn't if you should use one it's; why haven't you been using them?
Old Jun 5, 2013 | 06:58 PM
mxz800's Avatar
mxz800
Winter? Gawd we have had only three nice days so far.
Were you also one of those kids who talked about when school would start back up on the first day of summer break?
Old Jun 6, 2013 | 06:13 AM
C5Luv'R's Avatar
C5Luv'R
I've been using
Schumacher 1.5amp trickle chargers Schumacher 1.5amp trickle chargers
for winter storage on my "summer drivers" for 10+ years without an issue. On cars that I rarely drive, I permanently installed them for easy of use (plug-n-park). Since my C5 is only stored Thanksgiving-Easter, I place the charger on top of the battery temporarily and route an extension cord out the corner of the hood and over the side view mirror during winter storage.
Old Jun 6, 2013 | 08:02 AM
I've used a Battery Tender Plus for around 6 years - no issues at all. I keep it plugged into the car year around when its sitting in the garage.
Old Jun 6, 2013 | 09:31 AM
WvCorvette's Avatar
WvCorvette
Been using mine for 7 years...
Old Jun 6, 2013 | 10:25 AM
Baldfart's Avatar
Baldfart
I've had mine for ten years!
Old Jun 26, 2013 | 02:01 AM
john8642's Avatar
john8642
Default Where To Connect?
Do most of you guys just clip onto the battery terminals, or do you connect the two-way plug onto the fusebox and ground? I have even seen a cigarette lighter connection. Any thoughts about what is best?
Thanks,
John
Old Jun 26, 2013 | 02:11 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Clip onto the terminals for me. Do whatever works for you - just use it!
Peter
Old Jun 26, 2013 | 07:06 AM
bigcypress's Avatar
bigcypress
we have battery tender plus on both vettes year round .
Old Jun 26, 2013 | 07:43 AM
calvins's Avatar
calvins
Oldtimer
Peter
I did have the ring setup attached to the front posts but switched to the clips. No particular reason - juste didn't care for the looks with the hood open.
Old Jun 26, 2013 | 10:58 AM
QCVette's Avatar
QCVette
Originally Posted by C5Luv'R
I've been using Schumacher 1.5amp trickle chargers for winter storage on my "summer drivers" for 10+ years without an issue. .....
I have been using a different Schumacher 1.5 amp maintainer for a few years and it has been good. It has a desulfation mode that actually brought back one of my batteries that I thought was terminal.
Amazon.com: Schumacher SEM-1562A 1.5 Amp Speed Charge Maintainer: Automotive Amazon.com: Schumacher SEM-1562A 1.5 Amp Speed Charge Maintainer: Automotive
Old Jun 26, 2013 | 12:21 PM
old coons's Avatar
old coons
I just bought and installed this exact one the other day. Glad to hear you like it, because it was so cheap i was concerned. I had a 1214 code come up and thought I'd give a charger a try before I send my EBCM off to absfixer. Will finally have good weather tomorrow and will see if it helped.
To Batterytender/winter storage
