[Z06] SS Hoses
1-When you put them side by side on the table, the OEM ends are bigger and look much more stronger.
2- Once its install, the joint that is clip on the frame as a little movement(its make the hose move up and down by 1 or 2 mm ), the OEM was very tight and no movement at all.
Am I the only one who have that experience ?
