A/C, can you overcharge it!
Old Jun 17, 2013 | 09:30 PM
Rexde1's Avatar
Rexde1
Even if someone was dumb enough to try I dont think you could get coolant into the AC system.
Old Jun 17, 2013 | 10:04 PM
Ronnie wilkins's Avatar
Ronnie wilkins
Originally Posted by madmatt9471
(1) Yes you can overcharge it.
(2) Have you even checked the codes on the DIC, see the HVAC codes then get back to us. MAKE SURE YOU WRITE DOWN THE CODES BEFORE CLEAR THEM!
http://www.stengel.net/diccodes.htm
Corvette C5 Trouble Code Procedure - YouTube
(3) It is a known problem that the Actuators will get out of sync and end up doing what you are experiencing
http://forums.corvetteforum.com/c5-t...tuators-2.html
(4) You can reset/clear the codes from the HVAC and see that it will cycle through the actuators, try this and see what happens.
Let us know what you find!
Thanks,Matt
Matt,I did have a problem with a short last year that some of the tech guys on here help me find and fix so the battery was connected and disconnected quite often. Maybe that knocked them out of sink, I have no idea. I have not checked the codes yet but plan to do it this week. I will post what I find if anything. Thanks everyone for the advice.
Old Jun 18, 2013 | 03:42 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
The only decent advice you received was the poster who said get a can with the guage on it. It will have red yellow and green zones on the guage.
I used to have to top up every other year until I fixed the leak. The symptoms are warm air on the drivers side, cold on the passenger side. Believe me, I followed all the advice when it first happened and all it needed was freon.
And for all the forum police, it's R134a, not R134.
Swiped from the web:
Some people use the terms R134 and
R134a interchangeably, as seen in a
casual search of automotive websites
and storefronts, but they aren't
identical. The same number and type
of atoms make up R134 and R134a, but
the arrangement differs. Although R134
is technically a refrigerant, it's less
efficient at moving heat.
