No HVAC Mode Control
Old Jun 12, 2013 | 10:11 AM
RED-C5's Avatar
RED-C5
Default No HVAC Mode Control
I have a '98 with dual temp control. No matter which mode is selected, the air seams to come from all the outlets at a relatively
low volume with no change in direction (floor, defrost, vents etc). The blower speed works and temp control works. The A/C turns on in
the defrost position. No HVAC DTC codes. Where do I start looking?
Old Jun 12, 2013 | 10:39 AM
McAllister513's Avatar
McAllister513
Do a search and you'll get the full answer but it is most likely the vacuum line that goes to the back of the intake manifold down to the vacuum canister in the passenger side fender. Replace it with a rubber line and all will be fixed.
