dyno results question
Old Jun 13, 2013 | 10:10 PM
mobus's Avatar
mobus
Default dyno results question
Hello everyone, I just posted this in the scan & tune section but i realized there is much more traffic in this section, so i may receive a better answer here. I had my dyno tune today and was wondering if anyone could give me their opinion on the numbers my car made. First off it is a stock c5 coupe with bolt ons. Bolt ons include long tube headers, x-pipe with high flow cats, Borla straight pipes, Breathless performance ram air intake, ls6 intake manifold, slp underdrive pulley, 3800 vigilante stall converter, 3.42 gears. The car's baseline with all of the mods made 301.64 horsepower and 297.35 ft.lb of torque. the second run after the "tune" made 303.08 horsepower and 335.06 ft.lb of torque. I understand the numbers will be off because of the torque converter, but the horsepower only rising 2 hp seems VERY strange to me. The conditions today were 69 degrees with 75% humidity. Do these numbers sound right to anyone? Please let me know all of your opinions! Thank You
Old Jun 13, 2013 | 11:05 PM
NukeC5's Avatar
NukeC5
It depends on what dyno you ran on and how much it is corrected for or lack there of. Dynojets, mustang dynos, etc. all have somewhere between a 10%-15% increases in the readings shown to make up for a perceived correction need.
I went from a shop that had a dyno jet that read my car at 340whp with similar mods, and at the next shop, which used a "dyno log" dyno, (which has no correction). My car is now read at 305whp. Not that any power was lost, but they all read differently.
Old Jun 13, 2013 | 11:19 PM
mobus's Avatar
mobus
Thank you for the input! I should have mentioned it was a dynojet. Although, even if it was a lower reading dyno, my torque numbers jumped up almost 40 ft.lb. after the tune. Yet there was minimal, almost no horsepower increase at all. I may be over analyzing, but I just wanted to make sure everything sounded "right" I will try posting pictures of my graphs as soon as i get them into my computer.
Old Jun 13, 2013 | 11:32 PM
mobus's Avatar
mobus
http://s1363.photobucket.com/user/97...90790116542595
Hopefully this link works!
Old Jun 14, 2013 | 07:25 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Is your car an automatic? Typically, they dyno lower than an M6. I've seen stock A4 C5's dyno anywhere from the 285-310 rwhp range. It also depends on the dyno. The numbers are usually a little lower on a Mustang dyno. With those mods, I'd think you should be in the 335-350 rwhp range, but every car is different. My M6 '98 made around 320 rwhp when I had it dynoed for a baseline before I started modding it.
Old Jun 14, 2013 | 12:27 PM
matthewlfd's Avatar
matthewlfd
Here is mine on a Dynojet. M6, LS6 intake manifold, Vararam, B&B bullets, and monster clutch.
334 whp / 347 wtq
Old Jun 14, 2013 | 12:37 PM
hamhead's Avatar
hamhead
I'd take dyno readings on stalled cars with a grain of salt. If someone berates you for only dynoing 300whp, break out the timeslip from the track. That is what matters in the end anyway.
Old Jun 14, 2013 | 12:39 PM
kjohnson's Avatar
kjohnson
Heres my numbers from early last year on my 2000 A4 stock with 69k miles 3.15 gears
Sae corrected on a dynojet
Stock...291.04 Hp and 301.34 Tq
Tuned 303.09 Hp and 316.05 Tq
weather was between 70-74 degrees and 17% humidity.
Old Jun 14, 2013 | 12:50 PM
mobus's Avatar
mobus
Thanks for all of the replies. And yes I do take the Numbers with a grain of salt. I care much more about track Numbers then dyno Numbers. Although it was just confusing to me that the torque Numbers rose so much and the horsepower did not. If anyone can see in the link that I posted to my graphs, the air fuel ratio seems off to me dropping to high 10 low 11's at WOT and was way up around 16 cruising
Old Jun 14, 2013 | 01:18 PM
hamhead's Avatar
hamhead
I didn't look at that. I don't know what is going on with your A/F ratio. I'd slap my tuner in the face if I saw that and ask him to try again when he isn't drunk.
You should be at or around 12-13:1 A/F ratio all the way through the pull. Not lean as hell in the beginning and then going pig rich.
Example of a properly done dyno on a Corvette:
See the difference?
Old Jun 14, 2013 | 01:27 PM
mobus's Avatar
mobus
Wow huge difference! Thank you for posting that. By any chance, do you have a graph of your air fuel ratio?
Old Jun 14, 2013 | 03:27 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I have big power. But hamhead is correct there are too many
variables when using a dyno. It is a number and it vary's .
On the ground (track) is your best bet when talking numbers.
Dyno numbers can be confusing and does it really make a difference?
Just bragging rights. If you don't like your numbers increase
them, if that's important to you. Folks like me don't care, anyway.
Old Jun 14, 2013 | 03:29 PM
DevilDog II
Oldtimer
I'd take dyno readings on any car with a grain of salt. It's nice to be able to say you're making a high amount of rwhp, but you still have to get it to hook up. I have friends that are making nearly 600 rwhp, but they can't get out of the 12's because they have no traction.
Old Jun 14, 2013 | 04:42 PM
LoneStarLizzard's Avatar
LoneStarLizzard
Default 2002 C5 w/A4 results
My completely stock 2002 coupe (w/A4) baselined at 305 hp and 318 lb/ft. with a 2:73 gearset.
After adding a CAI (K&N), Z06 Ti exhaust and L/T headers, my results were 333 hp and 347 lb/ft, as tuned by LG.
I think the tuner can be conservative to aggressive in his tune, and your tuner may have been on the conservative side of things.
At the end of the day, you get off the line using torque. So your torque results are likely the ones you will feel in the seat of your pants.
More performance = more $$$$$$.
You can keep on adding mods until you either (a) run out of cash or (b) get the results you are finally looking for (not likely).
The Lizzard
Old Jun 14, 2013 | 06:02 PM
mobus's Avatar
mobus
I agree 100% that dyno Numbers are unimportant. But my main concern with looking at my graphs is how jagged the pulls are. The lines are not smooth whatsoever. Also the air:fuel ratio seems off to me as you can see in the graph I posted earlier in this thread. If possible can someone post a graph of their air:fuel ratio throughout their pull?
To dyno results question
