[Z06] Free heat reducing mod
Old Jun 25, 2002 | 08:10 AM
VettTheRipper's Avatar
VettTheRipper
Default Free heat reducing mod
I wanted to post this some time ago...
When installing my side vent screens I noticed something interesting.
First off, for those that are unaware, the side vents are functional. They allow hot air from the engine compartment a place to exit, mostly at speed. If you look inside of them, you'll notice a black piece of plastic. The function of that piece is strictly cosmetic and prevents you from being able to see less aesthetically pleasing parts under the body work. It also prevents the ducts from functioning to their fullest capacity. These shrouds (for lack of proper term) are easily removed from inside the compartments of the front wheel wells and open up a huge hole for hot air to drawn out due to the shape of the ducts.
I didn't remove them on my car (yet) since I'm waiting for my warranty to expire before I go racing and wouldn't recommend it unless you were in fact auto xing. (I doubt it would benefit a drag car since the ducts function at speed and you're not at speed long enough at the drags) For you track racers in the crowd this would be an easy way to get a little extra cooling under the hood. Probably not a huge difference but if you were to look at the ducts without the shrouds, you could plainly see the benefit. :cheers:
Old Jun 25, 2002 | 08:44 AM
pridnjoy's Avatar
pridnjoy
Cruise-In III Veteran
Default Re: Free heat reducing mod (VettTheRipper)
:cool: Never thought of removing these. Thanks
Old Jun 25, 2002 | 10:04 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Free heat reducing mod (pridnjoy)
Good theory.
If the fender liner were to be removed then the hot air from the engine compartment would have a route to be ejected by the side vents.
Unfortunately with the liner in place there is not much of a path for air to reach the side vent even with the part mentioned removed.
In practice the side "vents" are for styling.
Looks as if they've been a motif in Corvette styling since the inception.
If they WERE to be functional they would serve the aerodynamic function of reducing the trapped air that collects in the rear of the wheel well when the vehicle is driven at high speed.
Of course if you REALLY want yours to function, simply remove the inner fender liner.
Regards,
Old Jun 26, 2002 | 12:29 AM
AP's Avatar
AP
Cool ... this should work on all C5's ... I should try that ...
Old Jun 26, 2002 | 06:32 AM
VettTheRipper
Default Re: Free heat reducing mod (VetNutJim)
Good theory.
Regards,
:confused: Huh? :confused: The next time your car is at idle and hot, with the fans running, put your hand near the driver side vent and you will feel the hot air coming out. This effect is multiplied many times at speed as the ducts create a low pressure area that draws air out of the engine compartment. They are in fact a direct shot to the engine compartment, I've seen it. Remove your fenders liners? You would sandblast your PCM and a lot of critical wiring with road grime if you did that.
[Modified by VettTheRipper, 10:37 AM 6/26/2002]
[Modified by VettTheRipper, 1:35 PM 6/26/2002]
To Free heat reducing mod
