[Z06] PCV Valve
Old Jun 16, 2013 | 12:38 PM
wmjosjr's Avatar
wmjosjr
Default PCV Valve
Help, I have a 2004 Z06 LS-6 stock. I went to Chevy and bought a PCV valve Part #25179136-CV948C. I cant find the valve anywhere. I can't believe there isn't one!
Thanks,
Happy Fathers Day guys
Old Jun 16, 2013 | 04:35 PM
skyavonee's Avatar
skyavonee
Why did you buy it in the first place? Were you throwing a code?
This link makes me think you might have purchased the wrong piece:
http://www.tonkinonlineparts.com/p/C.../25179136.html
If this link is correct, you have the pcv valve for 97-03 Vettes. The system changed in 04, I think.
Old Jun 16, 2013 | 06:06 PM
racebum's Avatar
racebum
not sure if it changed in 04 but the valve is in a black tube by the throttle body on the passenger side with 02-03 cars. should be a little loop around tube that you can pull apart. inside is the pcv
ls1 pcv system is different
Old Jun 16, 2013 | 07:19 PM
wmjosjr's Avatar
wmjosjr
Thanks for your reply skyavonee. No codes. I just bought the Vette a few months ago, and was doing some pre-maintenance. it has 13,000 miles, and was sitting for a while.
Are you referring to a variable orifice type, or a fixed orifice type? I did get this PCV valve from Chevy, maybe the partsmen made a mistake.
Old Jun 16, 2013 | 07:21 PM
wmjosjr's Avatar
wmjosjr
Checked that location racebum, not there.
Old Jun 16, 2013 | 08:43 PM
tlove32's Avatar
tlove32
no pcv on the 04's....
Old Jun 16, 2013 | 09:14 PM
wmjosjr's Avatar
wmjosjr
Thanks tlove32, I was starting to think the same thing.
To PCV Valve
