[Z06] 10 Year Old Eagle F-! Tires
A knowledgeable driver interested in performance (or comfort, for that matter) won't come near 10-year old rubber.
If you have the room, wrap them in plastic and store them in the attic or garage. If you ever sell the Z, include them in the sale for the next owner. I think it would be nice to still have my original tires, but alas mine were worn, especially the fronts (down to the steel belts
Ryan J
Ryan J
If 10 year old tires were time bombs waiting to go off, we would hear of 15-20 year old low mileage "show cars" crashing all time because there are 10s of thousands of drivers using them every day and they would be having frequent blowouts.
Use motor oil as an example - some folks still swear by a 3k mile oil change even through you can clearly run synthetic much longer. There are plenty of members of this and other Vette forums that would have you believe you need to replace nearly every working part on the car before you would dare take it on a track. Some folks just love to spend money and want every nut and bolt to be newer and better than what they have now and claim that you couldn't be safe if you don't so the same thing. The Corvette of the last 20 years, and all its parts are designed to be driven 150+mph just as it rolled off the show room floor.
Now if you want to do that for 4 hours a day, every weekend, sure some mods will likely be necessary. If you want to pull 0.9g around street corners, yes junk the street tires at 10 years and 15,000 miles. But to go 65mph on a freeway in a straight line 90% of the time I don't see any issue. Most Vettes are so pampered, they've never even seen "hard miles".
Too each their own. My car is in the 10+ category and the only time my OEM rubber will be off the car is for track days. If it is a risk, it is one I am willing to live with.
Ryan J
as long as tread depth is ok-
Ryan J
personally i would never ever drive a tire over 5 years old. i try to aim for a 2-3 year replacement
traction is substantially lower by year 4 and by year ten you might as well be on roller skates
the reason you don't hear about show cars crashing is because #1 not many are on the road and #2 they are usually trailered and or driven 10 miles on a sunny day very carefully
there is no greater performance item on a car besides the tires. not the engine, brakes, suspension, nothing. everything goes through the tires.
you would literally be seconds down on a small 1 minute course
if the tire pulls 1g on said car you would be EXTREMELY lucky to see .90g at six years, it would likely be in the high .8 range
i don't understand why you guys own sports cars if you're going to neglect the single most important part of them
IMO Those are worst than the Faulty Valve springs that are known to come apart.
Somehow I read this as week 27, 2008, which is old but not terrible. Upon further review, they changed the tire dating in 2000. But...
Actually, I'm from the Clinton administration!
This is from a 2001 truck with high miles, so something tells me it's not quite OEM. Ergo, the used car dealer screwed me hard last October when I bought it.
Luckily, this happened going 20MPH about 1/4 mile from home so I could idle it into my driveway. On the other hand... I had put ~2800 interstate miles on this truck, out of the total ~3300 miles... Basically, my odds of dying or becoming a cripple were insanely high. Naturally, I kept my distance after I parked it, because I knew, eventually, this was coming:
Bam
I'm assuming buying it "as is" from the dealer = me out of luck. However, if there's not already a law banning the sale of 14 year old tires on a vehicle without disclosing it, there ****ing should be, because I could very easily be dead right now (or maybe SHOULD be dead, all things considered).
