Upholstery question
Old Jun 18, 2013 | 04:46 PM
SirKnite's Avatar
SirKnite
Default Upholstery question
My drivers side bolster (outside) has suffered some wear and I am trying to decide what to do about it. The seat bottom and other side is perfect and the passenger seat is also perfect. Since you can't buy just the one cover as far as I know, any anyway it seems to be very thin and would probably just wear out again fairly soon, I am thinking about having a Upholstery shop just redo the bolster with very heavy leather that can take the abuse.
Any thoughts on this would be appreciated.
Old Jun 18, 2013 | 06:24 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I think you're better off just buying a nice aftermarket set or perhaps a slightly used OEM set, depending on your budget.
Real leather aftermarket sets (which are better than the OEM pleather) can range between a few hundred dollars to a couple thousand for a complete set. Depending on the quality and level of customization.
Old Jun 18, 2013 | 09:33 PM
You are right that the stock seats are prone to wearing out rather quickly. There are a number of options for aftermarket seat covers that are made of much better leather material and will last a lot longer. I went with a set of Vette Essentials seat covers - certainly not the cheapest, but they have been on my car for better than three years and they still look like new.
Old Jun 18, 2013 | 11:16 PM
Rookieracer's Avatar
Rookieracer
The problem is the foam wears out, gets cut by the seat frame and then wears through the leather. I used some plastic tubing split down one side and wrapped around the edge of the seat back as well as the bottom frame. A little black gorilla tape to hold it in place during assembly and the problem is solved.
I found out about this solution on this forum!
There are instructions on Vette Essentials on how to change the leather seat covers if you decide to do it yourself.
Otherwise be sure to show the photos to your upholstery guy.
I also installed new foam.
The black drivers side sport seat bolster/halo leather is part # 88991787.
Old Jun 19, 2013 | 06:56 AM
lentislee's Avatar
lentislee
I had the same issue and went to the upholstery shop here in Bowling Green, Kentucky. They gave me the choice of a matching vinyl or genuine leather. I chose vinyl because of its durability. The match was perfect, the cost was $275 which included seat removal and sewing the insert.
The year was a 1999 C5 and color was light oak. The reason for the higher cost was that one had to order a minimum amount of material. I believe I have enough left to accommodate another bolster. Let me know your color and I will send to you (if its light oak) free of charge. Just reimburse me for the postage.
Lentis Lee
P.S. I now have a black 2004 C5, thus no future need
Old Jun 19, 2013 | 08:21 AM
SirKnite's Avatar
SirKnite
Rockieracer - Thank you for your pictures and fix. I will plan to do that to mine.
Lentislee - Thank you for your kind offer. My seats are black so I am not sure if you are saying you have some black as well. I am wondering if vinyl is really better then leather. Maybe it depends on the quality of the vinyl. I believe that the present bolsters are vinyl. Is this correct?
Thanks.
Old Jun 19, 2013 | 08:38 AM
lentislee's Avatar
lentislee
In answer to your question, my bolster that needed replacing was leather. The vinyl that they ordered for me was of an extremely good quality and I saw no results of wear in the two years that I used it.
The only vinyl that I have is the color light oak....sorry.
Lentis Lee
Old Jun 19, 2013 | 09:27 AM
3tt3v8P's Avatar
3tt3v8P
I just replaced my original sport seat covers with new ones. The old ones were in very good shape. No tears or punctures. They are black and are available if you have sport seats. PM me and we can visit. Thanks much.
To Upholstery question
