Tips on installing clear corners
Old Jun 21, 2013 | 05:39 PM
MAC5's Avatar
MAC5
Default Tips on installing clear corners
Reading through as many threads as I can find it appears the best approach to installing the clear corners mod is raising the front end and removal of the lower access panels.
The light assembly shows two holes for fastening, are there any other points that the assembly is secured to the front facia?
Any tips, details or reference to a previous install write up is appreciated.
Old Jun 21, 2013 | 05:45 PM
Zorlac's Avatar
Zorlac
JWMotoring has great instructions for the ones they sell on their website. Great vendor.
Old Jun 21, 2013 | 05:57 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
There is also a spring that helps secure the corners and maintains tension.
You can also go in from the top if you are planning an HID conversion to the headlights. I suggest that because I swapped out my corners from underneath the car and then two weeks later installed my ACA HIDs and HID fogs. Knowing after the fact how easy it was to remove the headlights, I would have waited and installed the corners/LEDs/Switchbacks at that time since I could have simply reached in from the top.
Old Jun 22, 2013 | 08:34 AM
This might help you out.
File Type: doc
Old Jun 22, 2013 | 01:39 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
appreciate the kudos.
Direct link: http://www.shop.jwmotoring.com/produ...categoryId=331
Thank me by ordering something if you haven't already
Old Jun 24, 2013 | 10:38 AM
MAC5's Avatar
MAC5
Thanks to all for passing along the installation information.
The installation is complete.
Took my time especially on the first side, and the second was a breeze. Definitely a good upgrade.
Old Jun 25, 2013 | 01:35 PM
Linusmcduffy's Avatar
Linusmcduffy
Default clear corners
This was one of the best mods that I did because of the clean look that resulted. Switched over to the 55W ballast HID fog lights for the complete look...
Old Jun 25, 2013 | 01:47 PM
04C5vette's Avatar
04C5vette
it's a lot easier to take out the headlight and work from the top IMO. i've done it several times.
Old Jun 25, 2013 | 02:11 PM
PeterB's Avatar
PeterB
Mac nicely done. May I ask did you by chance take before and after photos mo? It would be cool to see the diff. Thank you.
Nevermind Guy: VetteJacks attachments shows it pretty good. Thank you.
Old Jun 27, 2013 | 08:28 AM
MAC5's Avatar
MAC5
Here are a few before & after pic's. I went with the amber lenses to eliminate any NC yearly inspection hassles. Bulbs are white LED side lights, switchback white/amber running lights.
Parking lights on
Running lights only
Before
To Tips on installing clear corners
