[Z06] Another tire question
Jun 23, 2013 | 10:52 AM
I know that some are running 275-40/17 in the front rather than the stock 265s.
Does the 275 look that much different.
I really would like to get the conti extreme DWs, but they no longermake the 265s
Jun 23, 2013 | 03:32 PM
I can't tell any visual difference.
Vredesteins here.
Jun 23, 2013 | 07:47 PM
I'd be surprised if anyone could tell just by looking between the two. it's around a 3% difference in size.
Jun 24, 2013 | 03:12 PM
Checked on 1010tires and it is actually 1.24% diif. and 4mm taller.
I can't believe that I will be able to see the difference.
Jun 24, 2013 | 04:48 PM
you can see it, question is, will it bug you
that conti is kind of a fat 275
Jun 24, 2013 | 05:03 PM
Quote:
Originally Posted by
halp
Here is the Conti DWS (not DW) in 275-40/17:
I never noticed any issue with the extra few mm ....
Jun 24, 2013 | 05:17 PM
post a side profile of your car, wouldn't mind seeing the 275/295 conti difference
dws and dw have a similar sidewall
why did you put a dws on a corvette anyway? just for the couple db quieter ride?
Jun 24, 2013 | 06:18 PM
TheoZ
A side profile showing the front and rear would be great if you could post it.
Jun 24, 2013 | 09:45 PM
racebum
My rule is "No heavy loads, no gravel roads, no snow .... take the 'vette!"
So I wanted the All Season capability, hence the DWS. They are coming off as soon as the new Vredesteins get here. 30,000+ miles on the DWS and they never saw any S at all.
This is as close to a side shot as I could find .... probably can't tell anything but here it is:
Jun 24, 2013 | 09:49 PM
halp
4mm x 2. It should be 4mm taller on each side of the rim, thus 8mm taller. And it is 10mm wider.
Jun 25, 2013 | 07:56 PM
SKMCOBRA
OK 8mm taller overall. That's about 5/16 of an inch. It would still not be as tall as the rear tire.
Jun 25, 2013 | 08:16 PM
halp
it's not but it is in some cases as close as .4"
wear down the rears a little faster and it could be .3"
borderline TCS issues
the NT05 works because it's a short 275 and tall 295
contis are standard case
Jun 26, 2013 | 10:53 AM
racebum
Has there been documented evidence or a press release from GM that this could cause problems with the TCS?
Jun 26, 2013 | 01:13 PM
SKMCOBRA
better, people here have experienced it.
make a thread with a title of "tire height and TCS issues"
you'll get quite a few replies. probably more in c5 tech
