Passenger rear view mirror
Old Jun 25, 2013 | 05:23 PM
tommyo4's Avatar
tommyo4
Default Passenger rear view mirror
When I park my 97 coupe in the garage I spin the mirrors in to avoid any chance of scratching or hitting anything while moving around it. Today the passenger rear view will not click back into place. It just swivels loosely like something is missing or stripped. Any ideas how to fix without taking door panel off and removing assembly?
Old Jun 25, 2013 | 05:34 PM
CQRT's Avatar
CQRT
look on the floor and see if you can find the little white plastic ball that goes into the upper part of the mirror - - it sits in the indentation in the base . . .
Old Jun 25, 2013 | 05:40 PM
tommyo4's Avatar
tommyo4
Ok I popped the mirror off and it appears that the spring inside that puts pressure on the mirror to stay in place has a lock washer on top to keep the spring compressed. I need to compress the spring down and get that washer back on the post. It's really tight in there and the spring is pretty strong. A there any tricks or how tos ?
Old Jun 26, 2013 | 12:27 AM
Aerovette's Avatar
Aerovette
This has been discussed a few tmes on the forum and I stand by my belief that the ability to move them is a safety feature and they ar enot intended to be moved all the time. Your experience kind of verifies that point.
Just because you can, doesn't mean you should
Old Jun 26, 2013 | 01:48 PM
dadaroo's Avatar
dadaroo
Just search Google on C5 Corvette Floppy Mirror to get input.
To Passenger rear view mirror
