I had to order it from "dip your car . com" they have any color and you can get it in spray can or order gallons for dipping whole cars. spray cans are the same price as walmart though you do have shipping added on.
How did u get the sharp lines ? I imagine you have to remove the tape quickly. What do u do if you get the tape off and the rest still needs another coat ? I did my sons rims and it needed 5 coats for good coverage
I have tried a few things for getting sharp lines on the stripes. For me throwing down 3 fast coats and then pulling the tape while its still wet worked the best for the fenders.
The wheels I had to get a little more creative. I have about 8 coats on each wheel then I took a razor and carefully scribed a line on the machined lips to get it off without ripping the rest of the wheel off. Tried to tape the lips the first time and it always messed up the rest of the wheel.
This
Spray and let dry 3min, spray again and repeat 3-4 times
Pull tape, sharp line!
yep that's pretty much it,
I've tried it with just 2 coats, one light and one heavy pretty much works just as well but it's a pain in the butt when you pull it off cause its so thin. It breaks a lot on you. 4 coats is the magic number for most applications.
I did my pitted/dirty chrome Y2Ks with black, they look way better now and I get compliments. I love plasti-dip. The friend of mine that told me about it just did his 05' Legacy GT all black and he ordered the hit from dip your car . com. Turned out really nice.
Thanks guys! dip is lot of fun to experiment with on your car to see if you like a color or a scheme because as previously stated if you don't like it, get tired of it, mess up, or just want to try out a different color just peel it off and go again your out like $7 a can and 1 can does quite a lot.
