Any known starting issues
Old Jun 28, 2013 | 02:12 PM
mjones871's Avatar
mjones871
Default Any known starting issues
I've got a 2001 that I've only had for a couple weeks. Every time I've hopped in, it fires right up.....except today. Nothing but click, click, click. Battery seems find and when I roll started it, it fired right up. Just a starter?, or something sinister going on?
any thoughts out there?
Old Jun 28, 2013 | 02:26 PM
Zr-1Mike00's Avatar
Zr-1Mike00
There are many many threads on the no start issue. The advanced search feature is your best friend!
This is a good place to start:
http://forums.corvetteforum.com/c5-g...-confused.html
Old Jun 28, 2013 | 02:50 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Mine was doing the same thing, turned out to be a bad starter solenoid. Tap on the starter solenoid and if the car starts right up then could be a starter issue.
Old Jun 28, 2013 | 03:10 PM
PNW Vett's Avatar
PNW Vett
St. Jude Donor '13
I also vote solenoid, but would check no load battery voltage just to rule that out first. No load voltage needs to be >12.5 (some would even say 12.7).
Old Jun 28, 2013 | 03:37 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
usually a failing solenoid, or a corroded or lose connection at the starter solenoid.
Old Jun 28, 2013 | 03:40 PM
mjones871's Avatar
mjones871
getting down to the starter to tap it is a chore in itself
Old Jun 28, 2013 | 05:40 PM
Zr-1Mike00's Avatar
Zr-1Mike00
Broom handle works well.
Old Jun 28, 2013 | 06:52 PM
Evil-Twin's Avatar
Evil-Twin
a long handled crow bar works better. 24 inch with a straight end and a curved end
Old Jun 29, 2013 | 10:33 AM
mjones871's Avatar
mjones871
buddy of mine with an 02 tells me to try mashing the clutch to the floor. He says to really hammer it down and try it....darn thing fires right up and has been right every since. So now I'm learning about clutch switches.
Old Jun 29, 2013 | 11:17 AM
dadaroo's Avatar
dadaroo
Suggest you check the clutch switch adjustment and/or replace. Not real hard to do. You don't want to get stuck where you can't roll start. Other option would be to jumper around the switch. Us old guys never had that safety feature on our cars until the last 20 years or so. The C5 is my only manual car with that feature, everything else is 1971 or earlier. However, if you do the jumper and sell the car please inform the buyer you did that. If you need help on how to set the adjustment or replace the switch let me know. Mr. Sam
Old Jun 29, 2013 | 11:33 AM
mjones871's Avatar
mjones871
thanks Mr. Sam....If you've got details or instructions on setting the adjustment/replacing the switch, please share. I can catalog them in my "big binder of fixes"....
thanks for the info...
Old Jul 4, 2013 | 09:34 AM
dadaroo's Avatar
dadaroo
Looked at the FSM. Sorry, apparently there is no adjustment like the brake switch. It just says to remove the connector and then remove the switch. It must just snap in and out with tabs of some sort. You will need to remove the knee bolster to get access.
Old Jul 4, 2013 | 09:55 AM
Sids04's Avatar
Sids04
This was my starter issue
To Any known starting issues
