[Z06] Test drive question
Old Jun 29, 2013 | 10:18 PM
Joe_A's Avatar
Joe_A
St Jude Donor '15
Default Test drive question
Test drove a 2003 z06 today. 30K miles all stock.
At Highway speeds about 70-75 I am getting wind noise from the
drivers window sounds like top rear of window. Is there and adjustment
to tighten up the window is this a common issue. Other than that the
car was really great shape.
Old Jun 29, 2013 | 10:50 PM
bluestreak63's Avatar
bluestreak63
There is an adjustment to move the window in or out and forward or back I believe.
Did it have the tab on the moulding trim, which prevents window blowout at very high speeds?
Old Jun 29, 2013 | 11:10 PM
JeremyGSU's Avatar
JeremyGSU
I took my headliner out and between that and my windows it's noisy as hell on the highway. I didn't know you could adjust the windows. I'll have to take a look at it.
Old Jun 29, 2013 | 11:34 PM
Joe_A's Avatar
Joe_A
St Jude Donor '15
Yes the tab was present....
Do u know if the interior door panel needs to be removed to make the
adjustement ?
Old Jun 29, 2013 | 11:49 PM
vant's Avatar
vant
adjustement ?
I've adjusted both windows before and it's not that difficult. My door panels were off when I did it, but I don't think removal is necessary.
This might help. Reference step 4b.
http://www.vetteessentials.com/instr...or_handle.html
Also search the C5 forum for "window adjustment". Tons of threads on the subject.
Old Jun 30, 2013 | 09:28 AM
Camss57's Avatar
Camss57
Where is the car located? I drove one with the same issue and it turned out to be the weather stripping. It was torn and sticking out the top of the window.
Old Jun 30, 2013 | 12:53 PM
Joe_A's Avatar
Joe_A
St Jude Donor '15
Thanks to all the replies.
The link also helped
To Test drive question
