Catch can issues
Old Jun 30, 2013 | 04:09 PM
mikeyrko's Avatar
mikeyrko
Default Catch can issues
I purchased a Vette with a catch can installed.
I'm trying to figure out what is going on with it most catch cans I see only have 2 lines running to it.
anyway here are some pics maybe you guys can help me figure it out.
Old Jun 30, 2013 | 04:13 PM
NukeC5's Avatar
NukeC5
Ya thats definitely messed up. If you do not get help, I'll be able to explain the routing later today. Good luck
Old Jun 30, 2013 | 04:15 PM
mikeyrko's Avatar
mikeyrko
Thanks to be honest I look at try and figure it out but get confused by it all.
Old Jun 30, 2013 | 06:16 PM
Bent98c5's Avatar
Bent98c5
U need some better pics of the routing. It doesn't look that far off. Does it have a ls6 valley cover?
Old Jun 30, 2013 | 06:24 PM
meflyfrc's Avatar
meflyfrc
I agree. From the pic it looks like it only has two lines going to it.
Old Jun 30, 2013 | 06:45 PM
Bent98c5's Avatar
Bent98c5
Just saw the 243 on one of the heads. So ill assume its ls6. U need to say also if u have lines to each valve cover.
Once u post this info it won't be hard to help you out
Old Jun 30, 2013 | 07:12 PM
mikeyrko's Avatar
mikeyrko
It is a ls6. I will get some more pics when it stops raining where I'm at.
The part that bugs me is the 3 way T in the middle.
Old Jun 30, 2013 | 07:16 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Mine only had an in and a out, I don't see why there would be a T in there.
Old Jun 30, 2013 | 07:21 PM
Bent98c5's Avatar
Bent98c5
Ok. If u have lines on the back of ur valve covers cap those off. In the top pic take the line on the right of the t off. then u have a line from the tb to the front of the pass valve cover where there's a black line coming from it and going to the t- then red line to the tb.
The other 2 lines look to be fine. I'm gonna pm u a link with the type of pic u need to take in order to be sure. (Basically a pic of the correct way it should look)
Old Jun 30, 2013 | 07:29 PM
Mr.Bill's Avatar
Mr.Bill
These might help.
http://www.customcorvetteaccessories...lcatchcan.html
https://store-581ad.mybigcommerce.co...uctions_CC.pdf
Old Jun 30, 2013 | 08:31 PM
mikeyrko's Avatar
mikeyrko
Ok here is one more pic of it.
Might be a stupid question this is the pcv valve correct?
do I keep it with the catch can?
and is this a stock part or something added for the can?
Old Jun 30, 2013 | 09:30 PM
Bent98c5's Avatar
Bent98c5
That's a stock part. The pcv valve goes in it. Also u dont need any of those zip ties or clamps. And the pcv valve looks right but a new ones cheap and easy to get.
Get a new black boot piece (3rd pic) put the small end to the bottom fitting of the catch can and then stick a new pcv valve into the big end (big side of pcv valve) and then run hose from that to the intake manifold.
Your top fitting on can should go to the valley cover. It appears to be correct already.
Then just do what I already said with the t and your set. Sry that my terms aren't super technical. Hopefully they are understandable
Old Jun 30, 2013 | 09:49 PM
mikeyrko's Avatar
mikeyrko
I'm going to work with it this week I think I have it figured out. I will be asking more questions if not haha.
Old Jul 1, 2013 | 02:17 AM
john8642's Avatar
john8642
Would a stock LS6 benefit from a vendor catch can? I know the hose routing was improved on the stock PCV, but is it enough to prevent the previous problem of the LS1s. I have a stock '03 Z06, and may do a few mild mods. Just wondering if would be best to start with a catch can?
Thanks,
John
To Catch can issues
