r1 concepts brake upgrade
Old Jul 1, 2013 | 08:58 PM
dolphins.1975's Avatar
dolphins.1975
6th Gear
Default r1 concepts brake upgrade
would anyone have any info on r1 concept brakes
Old Jul 1, 2013 | 09:29 PM
Sidewayz6.0's Avatar
Sidewayz6.0
Bought from them probably 10 times. Nothing but good things to say. When I replace brakes on any of my vehicles, I go with the E-Line drilled, not slotted. And Posi Quiet pads. The E-Lines are zinc coated. The premium have the painted hubs. But they rust and look like **** after a while. Go with the cheaper ones. I've used both in the past.
Old Jul 2, 2013 | 10:44 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
What are you looking to accomplish with your braking system?
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Jul 2, 2013 | 08:28 PM
phil hunter's Avatar
phil hunter
Had slotted R1 Concepts on a Chrysler 300C . They solved a rotor warping problem I had. Would highly recommend them.
Phil
Old Jul 2, 2013 | 09:00 PM
steveovette's Avatar
steveovette
Used the slotted and drilled on my Cadillac CTS and they were very noisy on hard application as if they were not machined properly. Threaded? Ended up replacing with some Delco's. Problem solved.
Anyone want a set of rotors for a 04 CTS sport and performance model?
Old Jul 2, 2013 | 10:04 PM
Sidewayz6.0
Thats why I skip the slotted. Drilled only.
Old Jul 5, 2013 | 08:15 PM
dolphins.1975
6th Gear
thank you for the tips I greatly appreciate it .
Old Jul 5, 2013 | 08:17 PM
dolphins.1975
6th Gear
i really just looking for a nice look and performance .I plan on taking to Watkins glenn here and then with a club
To r1 concepts brake upgrade
