Buying my first Corvette
Old Jul 3, 2013 | 10:48 PM
jph1972's Avatar
jph1972
Default Buying my first Corvette
Hi All,
I have an opportunity to buy a mint condition 97 C5 with only 62K original miles for $13,000. I found out today that the A/C does not work so I asked the seller to knock a little of the sell price which he did the new sell price is $12,700.
My questions is do you think the $12,700 is a good price for this year Corvette. Vehicle also comes with 2 sets of rims, OE and aftermarket.
Thanks for your input.
Old Jul 3, 2013 | 10:52 PM
baxsom's Avatar
baxsom
Make sure you go through the used corvette checklist that they have listed on here.
Check the codes 97-00 have certain things that once they go wrong cannot be repaired like the EBCM. If you see a code for that your anti lock brakes will never work. Also check the water seals around the targa. Feel the carpet behind the seats. Look for the differential to be leaking on the left side. Check the seats to see if they rock back and forth. With the exception of the EBCM all those are easy but expensive fixes.
Old Jul 3, 2013 | 11:09 PM
jph1972's Avatar
jph1972
Thanks Baxsom,
I did review the check list which was very helpful. From what I gather the car is still drivable if the anti locking breaks are toast. I test drove the car in the rain the other day and did notice a few water drops leaking past the seal, but for a 16 year old car I kind of expected some leakage. I read that some silicone grease may help with this.
I did not notice the rear diff leaking but will take a look this weekend.
So how about the price? is $12,700 a decent deal.
Old Jul 3, 2013 | 11:49 PM
ClipperFan's Avatar
ClipperFan
I paid 11k for my 97 manual trans Corvette a couple months ago but it needs seats and other cosmetics. 125,000 miles but it runs great. Good luck
Old Jul 3, 2013 | 11:53 PM
How good the price is really depends on what it is going to cost to get the A/C up and running again. Could get expensive. But if it is a fix that doesn't run into a lot of dollars, I'd say the price is OK.
Old Jul 4, 2013 | 01:44 AM
memmer's Avatar
memmer
If the AC needs major repair then that $300 savings will not go very far to help.As far as the price,if every thing else is OK then it doesn't sound like a bad deal.You might want to call a dealership and ask what a worst case repair would cost.GL
Fred
Old Jul 4, 2013 | 03:38 AM
jdot's Avatar
jdot
Well when you were told it was "mint" that to me means everything works and the car looks immaculate. If the AC isn't working the price is going to come down or I'm leaving.
Old Jul 4, 2013 | 08:05 AM
Sonny71's Avatar
Sonny71
Oldtimer
Price of $13,000 seems high, even for low mileage. I'd keep shopping and try to move up to the '01 - '02 range.
Old Jul 4, 2013 | 08:34 AM
jph1972's Avatar
jph1972
I did call a local dealer and was told it would be between $500-$600 to replace the compressor.
Old Jul 4, 2013 | 08:35 AM
jph1972's Avatar
jph1972
I live in the Boston area and all 2000 and higher Vetts are selling between $18K-$20K in this area. This is out of my price range.
Old Jul 4, 2013 | 11:35 AM
92GA's Avatar
92GA
Oldtimer
Price don't seem bad to me. Around here if you find a C5 under $16000.00 they need some work, or are very high miles, and they will still need some work. Just because the air don't work, don't automatically think it needs a compressor. My car with 143,000 miles has a seal leak, and I have to add refrigerant every spring after it sits all winter. It still works great when charged correctly. I can add a lot of gas with what a shop charges to replace the compressor. I can't do that kind of work anymore.
Go for it,, if the car is what you want ! It's your money, spend it the way you want.
Old Jul 4, 2013 | 11:43 AM
Jeff73454's Avatar
Jeff73454
Cruise-In III Veteran
Don't be afraid of a 97. I paid a little extra for mine but it was in brand new condition with 19k miles on it. My ac did not work and it only cost $75 to have it recharged and checked for leaks. Just be prepared to change all fluids. You will spend a lot more for an 01-04 car in the same condition.
Old Jul 4, 2013 | 11:57 AM
danieloneil01's Avatar
danieloneil01
You don't just replace the compressor.
Old Jul 4, 2013 | 10:11 PM
jdot's Avatar
jdot
When all is said and done and I've looked at all the cars I can't afford, I realize I will always do the right thing. I let my wallet be my guide once I find "the" car. From that point of view it's an easy decision to make.
Old Jul 5, 2013 | 10:22 AM
jph1972's Avatar
jph1972
The current owner actually changed the belt to by pass the compressor all together but told me the compressor is bad. Other than that there is no other problems I can see. I am having is inspected by a local dealer on Monday. If all goes well then I am going to buy it.
Thanks.
Old Jul 5, 2013 | 01:16 PM
Phanni's Avatar
Phanni
See if you can get the owner to split the cost of the repair/new AC compressor with you.
Old Jul 5, 2013 | 04:21 PM
BACNBLK's Avatar
BACNBLK
Good luck, these C5s are great cars, and lots of fun!
To Buying my first Corvette
Old Jul 5, 2013 | 05:13 PM
Frank4202's Avatar
Frank4202
Don't be afraid of going with a 97. Mines a 97 with 55,000 miles. Runs beautiful and haven't had a problem....Yet
Old Jul 5, 2013 | 07:22 PM
kennedy759's Avatar
kennedy759
I just paid $14.5k for my 97, 88k miles, so far replaced ww pump, adjusted one head lite door, still need to replace one sagging door hinge, and clean the k & n free air filter, otherwise perfect. Came with two sets of rims, original and zr-1 aftermarket, custom interior, new tires, $1500 tune up(plugs, wires, belts, hoses) headlite motors replaced, ww motor replaced, a/c serviced, and alignment done by previous owner. Like you, this was in my price range, would have liked a newer one, but way too expensive.
Old Jul 5, 2013 | 08:21 PM
racebum's Avatar
racebum
price is around going rate and fair
just get a tally of how much you will have to replace. the $300 off will cover your AC pump, but, i would replace the radiator while i was at it. 15yrs is a lot of age and debris on a plastic end tank rad.
tensioner pulleys may also be shot
fuel filter, plugs, wires, air filter, all likely replacement items
jack up car and check wheel bearings for run out, inspect brakes
few things off the top of my head that haven't been mentioned
